Suzuki-Forums.com is the premier Suzuki forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 04-12-2007, 02:33 PM   #1 (permalink)
blinton25 is on a distinguished road
Default 1998 Baleno Erro Code 47
Hello,
Start car, drives well for 10 - 15 mins, then engine starts to lose power unless accelerator is pressed. After a few minutes a slight backfire occurs, the Check Engine light flicks on, and then the car drives normally.
The check engine light flashes 47, but I don't see that error code at:
troublecodes.net/suzuki/
blinton25 is offline   Reply With Quote
Old 01-18-2008, 11:06 AM   #2 (permalink)
Guillermo Gonzalez is on a distinguished road
Thumbs up Cmp Sensor
The problem is located in CMP Sensor, the 47 code refer to a cmp sensor.
Guillermo Gonzalez is offline   Reply With Quote
Old 01-18-2008, 04:51 PM   #3 (permalink)
Hello,
Thanks very much, you are correct.
Old 01-24-2008, 09:35 PM   #4 (permalink)
Default Cmp Sensor
I have the same problem. Do you replace this sensor?, I found this code in another service manual, but i test this sensor, and not found problem,The failure might happen because of an increase of the temperature of the sensor. This could be altering the values sent to the ECM.
