Old 07-25-2008, 12:10 PM   #11 (permalink)
jim_naisium is on a distinguished road
Well, there are two ways to clear the codes...
1 - Unhook the NEG cable from the battery for five minutes and hope the light doesn't turn back on.
2 - Or as I previously said hook an OBD-II scanner up to the car (Autozone does NOT charge anything to do this (at least mine doesn't)) they can tell you what is wrong, give you a little print out about possible conditions causing it, then clear the codes to turn the light off.
There are numerous reasons for the light coming on, all of them should still leave your car drivable if there was anything wrong chances are you probably have noticed it already, like the engine running rough, white, black, or blue smoke coming out of the tail pipe, very bad gas mileage, etc.
Someone previously mentioned their O2 sensor being bad for two years, on the Esteem it uses the "4 wire" O2 sensor instead of a 1 or 2 wire, two of the wires are for the actual sensor, the other two are for a pre-heater circuit that makes the O2 sensor heat up really fast so that it starts doing its job sooner. The pre-heater blowing its heating element (creates an open circuit) will make the "Check engine" light come on, the O2 sensor will still work fine to keep the engine running like it should but to fix this the entire O2 sensor still has to be replaced.
jim_naisium is offline   Reply With Quote
Old 07-25-2008, 06:08 PM   #12 (permalink)
Isuzuzuki man's Avatar
O2 Esteems are OBD II, removing the battery will do nothing for the codes, you have to have them reset with the scanner on it. I would NOT drive due to the clunk, not necessarily the CEL.
A-Z can reset the code, if you can find one who is willing, they are not supposed to. Good to have friends there.
2002 Suzuki Esteem Wagon
2002 Suzuki Esteem Sedan
2002 wagon
2002Esteem 4 dr
my first Esteem RIP
1992 Impulse
Old 07-27-2008, 06:19 AM   #13 (permalink)
ernesto ballesta is on a distinguished road
hello christopher
i belive the best way to find out the problem is....hook up your to computer to analyze and find out the real problem ... i have the same problem you have before my car actually idles and then off found out that on e of the chip in the computer management is faulty
ernesto ballesta is offline   Reply With Quote
