Hi all,
The central lock on my Baleno 1999 1,6 stopped working a couple a days ago. Not just the remote, but the entire central lock system, using the key or the lock button inside the car - it's DEAD!
I have changed the fuse, just in case, even if it looked OK. I have also checked ALL the other fuses - none of them broken. I suspect it's a relay problem, since the irritating beep when leaving the keys in the ignition when opening the drivers door went away at the same time, and the "fog light" button in the car is acting kind of strange. The button has a little green indicator that lights up now and then.
Do anyone have knowledge of where the relays for the central lock and fog lights are located, or do you have a wiring diagram that could help me out here?
Any other ideas are of course most welcome
Best regards from Norway!
