Old 02-26-2006, 01:48 PM   #1 (permalink)
BalenoSport
Thumbs up
Hi everyone!
First of all my english is not so good because my main lenguage is spanish so I apologise If I misspell of canot express myself well. I have my Suzuki Esteem since brand new and after being able to do 16.0 at the 1/4 mile with only Basic alterations to the car so I decided to turbocharge the car. It has not been easy, I had to alter the transmition, decide how I could exactly mount the intercooler and since there are no performance parts for the car I had to made a few of them (the mainfold was the most dificult). Anyways halway, when I was testing the car, I made the grave mistake to use the car without installing a good racing gas pump and the car went lean and the piston rings simply gave up. Since I have to rebuild the eingine I was thinking that if I could mount stronger, lower compresion pistons so I could add more boost one I get a decent gass pump. Do you guys know what pistons I could use on my J18A? I could also use some suggestions, here are some pics of my car.
BalenoSport is offline   Reply With Quote
Old 02-28-2006, 02:34 PM   #2 (permalink)
sobi_man
Hi listen up... just lemme know if your Turbo charged is working alright?
I got a 1.6 Baleno... all I wanna do is get it turbo charged... can u kindly let me know all the equipment necessary to get it turbo charged?
List things plzzz...
and which turbo are u using? I mean which company or which car did u get it off from???
Do so I got a race by the end of next week Help me dude...! I just got the 1.6 Engine for myself...!
Help Required
Regards
sohaib_m_a_n@hotmail.com
sobi_man is offline   Reply With Quote
Old 02-28-2006, 06:37 PM   #3 (permalink)
RandomHero_666
Thumbs up
Is that a 98 esteem or a newer esteem?
RandomHero_666 is offline   Reply With Quote
Old 03-23-2006, 06:14 PM   #4 (permalink)
BalenoSport
Its A 2001 Model, a 1.8L J18A Engine
Old 03-26-2006, 06:59 AM   #5 (permalink)
zestarm
Whoa ... Such a giant turbo u have man! ... hahaha...
peace..
zestarm is offline   Reply With Quote
Old 05-01-2006, 03:26 PM   #6 (permalink)
neo_trace
i have 1.6L baleno and i m from india i have used Garrett T3 turbo with front mounted air intercooler and turbosmart blowoff walve with boost controller.
i m going to upgrade my piston sets to ROSS forged piston
right now i m using 4 psi boost ..problem is when i set boost to 8 psi MAP sensor on menifold cuts off power and shows check engine light..what is tha solution to MAP sensor....so i can use very high boost
i will send picture very soon...
please help me
neo_trace is offline   Reply With Quote
Old 06-27-2006, 05:37 PM   #7 (permalink)
TTGOTH's Avatar
TTGOTH is on a distinguished road
Good job on the turbo. I put a GT25 on my 2000 1.8 took it for a run down the interstate got almost home and it caught on fire. Unsure of were you live but in Florida it gets kinds hot. Use a good fan for under the hood. So the Reno is getting supercharged, Low boost, Lots of vents.
http://tt-goth.blogspot.com/
TTGOTH is offline   Reply With Quote
Old 07-06-2006, 01:14 AM   #8 (permalink)
rohanrohipnol
Default man, you have balls
Hi Balenosport,
just wanted to tell you that I think that it is great that you have put a turbocharger on your baleno and have sent in info and pictures. Fantastic!!
I've got a 1.6L Baleno but no way would I risk it, I need my car on the road and besides i paid way too much for it to risk such mods.
By the way I want to say that your English is pretty good and better than some of the contributors whose first language is English.
keep up the good work!
rohanrohipnol is offline   Reply With Quote
Old 07-06-2006, 10:52 AM   #9 (permalink)
amsyl is on a distinguished road
Hi Neo_Trace, the MAP is not designed for forced induction. Once it encounters a higher pressure, you will get a engine check light. You need a electronic device to limited the signal that the MAP receives under boost. A piggyback ecu like the Unichip can be used to 'clamp' the voltage so that you can run higher boost. Good luck on your search.
amsyl is offline   Reply With Quote
Old 11-11-2006, 07:32 AM   #10 (permalink)
neo_trace
Does Unichip Work With 1.6l Turbo Baleno ?
What Is Partno. And Price And Where To Get In India?
