Old 11-13-2006, 05:02 AM   #11 (permalink)
amsyl is on a distinguished road
We do not know of the agent in India. Alternatively, you can use a black box that clamps the voltage signal so that you engine check light does not come on and stall at higher boost. What about additional fueling? Are you using anything such as additional fuel injectors? If you want something simple that you can tune yourself we can recommend something.
amsyl is offline   Reply With Quote
Old 11-14-2006, 04:40 AM   #12 (permalink)
neo_trace
sure i want something simple that i can tune myself...show me the solution that u r talking
and
what is black box?
nope i m on stock 4 injectors ..how to put additional fuel injectors?
what @ putting bigger fuel pump?
what is yor recommandation?
plz reply
thanks
neo_trace is offline   Reply With Quote
Old 11-14-2006, 05:02 AM   #13 (permalink)
Based on your pictures, we assume that you are using higher fuel pressure. This will ultimately wear out the stock fuel pump. You should uprate the fuel pump. Basically, you are just throwing fuel into your engine to run it richer and this will affect fuel consumption and power. The Black Box with just clamp the signal of your MAP sensor and allow you to run higher boost. The electronic controller allows you to control the additional fuel provided by the twin additional fuel injectors that are fitted before the throttle under boost.
Old 11-16-2006, 03:43 AM   #14 (permalink)
neo_trace
yes i m using FSE rising rate fuel press. regulator.
A fuel pump from Honda accord or CIVIC or any other higher BHP cars will solve the fuel feed problem?
what is the price of black box and where i can buy that?
what is tha price of additional fuel injectors and where can i buy that?
will LPG gas injector will solve problem?
Old 01-15-2007, 10:10 PM   #15 (permalink)
TTGOTH's Avatar
TTGOTH is on a distinguished road
No............
http://tt-goth.blogspot.com/
TTGOTH is offline   Reply With Quote
Old 11-13-2007, 10:48 AM   #16 (permalink)
orlioe's Avatar
orlioe is on a distinguished road
My Baleno G13BB has a 4 psi turbocharger from Charade 1.0 T. I have LPG injection system and it's easy to change the size of the LPG nozzles. I didn't make any changes to the stock fuel system still, so on LPG it's running much better. I also have this MAP problem and knocking from valves when the pedal is under 40 % pressed. I gues it's from a high compression. Do u have the same thing?
orlioe is offline   Reply With Quote
Old 11-21-2007, 01:48 PM   #17 (permalink)
maal15 is on a distinguished road
I got a 99 and would also like a list of parts you used to turbocharge. My email is jamaa_zachry@yahoo.com
maal15 is offline   Reply With Quote
Old 12-08-2007, 10:53 AM   #18 (permalink)
mindcloud's Avatar
mindcloud is on a distinguished road
hmmm wondering if this TC could be apply to my baleno NextG.
wew!
mindcloud is offline   Reply With Quote
