Well, I have disassembed the gear box and I like to make a correction, as on my previous topic I said that the left case plate is hold in place by five bolts,actualy there are six of these bolts not five.The left case plate found warped and cracked on removal.The cup of the roller bearing moved about two millimeters above the surface ,as this should be below the surface of the left case.I f any one needs any info ,I would be pleased to help out.
