Originally Posted by Hanukkah
I have yet to fix the poblem. But I adjusted the clutch cable free play and it was minimized a bit.
The new clutch you put, is the friction material sintered?
Well good morning ! There is some one who talks about Alto clutch problem. Maruti auth service is not able to appreciate this problem. I replaced complete assembly, don't know it is sintered or not. I believe there is something called re-inforced clutch which gives better life and stability. I also adjusted the cable and adjusted the play, however the confidence one should have while using the clutch, specially in a heavy traffic is still not there. I being a mechanical engineer can't appreciate a clutch like this.
I have decided to go to some third party and do the job in my presence. If that also fails, the best thing I can do is sell the car to some poor fellow, who will join this forum.
I live in Calcutta, by the way where do you live.
Rgds
Nilanjan
