code p0171 - Suzuki Forums: Suzuki Forum Site
Old 03-27-2011, 02:47 AM   #1 (permalink)
azsuzuki is on a distinguished road
Default code p0171
2002 Aerio with p0171 code -engine running lean
On cold starts especially cooler or cold mornings, the car is sluggish after starting. It takes a few minutes for this to clear. It accelerates slowly and does not run better until warmed up or at higher speeds.
Running at 2k+ revs it is fine and does not miss or stutter. Acceleration is okay. But when slowing for lights or stops, revs drop usually to sub 600 and the car will stall. This happens too when attempting to accelerate from a stop at a light. Tapping throttle usually stabilized it. Hard acceleration from the near stalling state gives some backfire (?) sounds
I have cleaned out the EGR valve, inspected IAC valve, replaced PCV, replaced two short hose tubings between header and throttle body and cleaned the mounting holes, checked visually and audibly for intake leaks, inspected both o2 sensors, spark plugs replaced last year, visual inspection of exhaust (engine not running) showed no leaks or breaks...
Multimeter tests of EGR and IAC are normal, as did both o2 sensors.
This problem is consistent and persistent. Had different problems last year and had serious, heavy, black soot from exhaust once or twice on start up after repairs but never since. Did the EGR cleaning after this.
Any thoughts or suggestions would be appreciated.
azsuzuki is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 12:11 PM   #2 (permalink)
Tomh is on a distinguished road
Maybe a cogged fuel filter/injector? How many miles on the car?
'05 Twin Turbo GTO - 2 engine rebuilds, 4 clutchs, 6 sets of tires, 85k miles
'06 Aerio - routine services & 3 sets of tires, 125k miles.
Tomh is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 12:48 PM   #3 (permalink)
The car has 170k miles.
It runs smoothly at speed and accelerates well after initial sluggishness so I am not thinking the problem is with the fuel supply. It only bogs down when coming to a stop and at start of motion.
Possible that the IAC valve is electronically sound but not mechanically?
Thinking of retesting the o2 sensors.
Cold weather and cold engine exaggerate the problem.
Old 03-30-2011, 01:10 PM   #4 (permalink)
It does sound like an IAC issue. Have you tried cleaning it with some carb or electronic component cleaner? Not too much... just enough to flush it out. Might be worth checking vacuume lines too.
