03 aerio are these engines interference motors. if so when is a good time to change out the timing belt. thanks for any info this is gramma's car and she is on a fixed income so I will be asking alot of questions.
the 2.3 also has a timming chain. as for it being a interference motor that is unsure. but do to its low compression and lack of a VVt system i doubt it is. But since you don't have belt i wouldn't worry to much about this unless you raise your compression , adjust your timing too far, cams, ect., then you dont have anything you have to worry about.
__________________ 2006 sport mind edition Aerio SX MODS INCLUDING AEM Intake, Mandrel Exhaust, Racing Dynamics Engine Comps,NGK Ignition, Custom Engine Electronics, KSPORT COILOVERS!!!!, SWT Strut Bars, Custom Brakes, Custom Transmission, Custom MAF/IAT Tube, 160 degree thermostat, Fujita air filter, MaBo ground wires,... To much to fit check out my car domain http://www.cardomain.com/ride/2349923
For all things Aerio the best forum is http://www.aeriostyle.com/forum/index.php
timing chains usually out the last the car. I know on my ranger for example the timing chain was in great condition even after 500000 miles.
The chain would never need replacing. There are oil driven tensioners that keep the chain at the appropriate tension. So I wouldn't recommend to wait to long on oil changes as sludge can affect the performance of the tensioners and can create a knocking noise.
I'd seen some very abused Aerios and the tensioners never seem to make noise on the 4 cylinder Suzukis. just the V6 ones lol - EVEN with good maintaince they still fail.
