Old 10-21-2009, 09:49 PM   #1 (permalink)
9o9o is on a distinguished road
Default eh? fuse constantly blowing
Installed sound system and everything was fine for bout a month and now... a 10amp fuse that controls my interior lighting and tail lights is constantly blowing on me,
I dont even have to turn on the car to get it to blow. checked all the wiring from the lights and everything and im thinkin its my stereo but y would it suddenly happen now.
I did however leave my lights on the other day and had the car jump started, could this of caused the constant blow?
9o9o is offline   Reply With Quote
Old 10-23-2009, 12:47 AM   #2 (permalink)
Devilsword is on a distinguished road
Did you splice into any 12volt power source for your System? i know some amps want you to tap into a 12v source that is only on the the car is. Most of the time people f this up and cut into the fuel pump, it over loads the circuit and pop goes the fuse and the car is dead. though most people don't now that most head unit have a hot just for that.
2006 sport mind edition Aerio SX MODS INCLUDING AEM Intake, Flowmaster Exhaust, Racing Dynamics Engine Comps,NGK Ignition, Custom Engine Electronics, KYB Shocks, Eibach Springs, SWT Strut Bars, Custom Brakes, Custom Transmission, Custom MAF/IAT Tube, 160 degree thermostat, Fujita air filter, MaBo ground wires, Sharpened Throttle Plate, Improved and Blue-Printed Throttle Body, Blue-Printed.. To much to fit check out my car domian http://www.cardomain.com/ride/2349923
Devilsword is offline   Reply With Quote
Old 10-23-2009, 04:20 PM   #3 (permalink)
Installed a sound system and now, a few months later you have an intermittent fuse blowing issue on the interior lights.
Well - there's usually a lead in the stock harness that feeds the factory stereo(radio) that includes a lighting connection - it's normally used to either power backlighting on a radio that doesn't have an illuminated display - or - to dim the display when the lights are turned on.
I'm going to guess that you pinched this wire when installing the stereo and after a few weeks of chafing, you've worn the insulation away and now have a bare spot that occasionally shorts to ground, and clears the fuse.
Old 10-24-2009, 11:54 PM   #4 (permalink)
Took the headunit out and had a look and no bare wires in there anywhere.
I crouched near the fuse box and put a fuse in and watched it as i switched on the lights and instant boom of the fuse.
Going to try take out the bulbs of each light and see how that goes, if this doesnt work. Is there other suggestions?
Want to try work it out myself before paying heaps for it to be fixed
Old 10-26-2009, 08:46 PM   #5 (permalink)
Lord_Platypus is on a distinguished road
Default same problem!
I have almost exactly the same problem!
I took the car to a shop, and they found two loose ground wires. Its blown once since then but has been okay for a while. I too replaced the head unit a few months ago but hadn't thought that it could be related.
If I learn anything new I'll let you know.
Lord_Platypus is offline   Reply With Quote
Old 10-26-2009, 09:01 PM   #6 (permalink)
cheers m8, would b a HUGE help.
I havent tken the bulbs out n tried yet havent had time haha been avoiding night driving lol
But yeah i didnt see any loose wires in there where i took the lights off
Old 11-03-2009, 03:19 PM   #7 (permalink)
The loose wires weren't by the lights. The first one was somewhere under the dash, the shop I took the car to had to remove the steering wheel column to get at it, or something like that. I didn't witness the actual repairs. I don't know where the second wire was cause I didn't have time to take the car in myself, traded with a friend and he took it in.
Anyway thats all I know. If I learn anything else I'll post it.
Old 11-03-2009, 07:19 PM   #8 (permalink)
double trouble is on a distinguished road
loose grounds do not cause dead shorts.just dead lights. pull the bulbs. leave all the bulbs out and try it .if not check the sockets for rust,then clean and lube. check the sockets for bent tabs , i the bulb is causing it replace the bulbs because they short out sometimes, if not then check behind the sockets for bare spots in wires. next check behind the switch for wires touching too.
do you know how to use a continuity tester. you might want to learn. that is next. cheap ,but effective.
double trouble is offline   Reply With Quote
