Old 07-17-2009, 01:25 PM   #1 (permalink)
sidekickmitch is on a distinguished road
Default 05 Aerio manual transmission fluid change
What/Where can I find the instructions to change the fluid/oil in the transmission and/or transaxle in an '05 Aerio. What type of fluid does it take?
Thanks!
sidekickmitch is offline   Reply With Quote
Old 07-19-2009, 10:52 AM   #2 (permalink)
There is a big bolt at the bottom side of the transmission case. A 15/16" wrench will work to crack it loose.
Pull the lug out and let it drain. Refill with around 4-4.5liters of Dexron 3 ATF.
I'd recommend doing this, driving the vehicle 100miles or so and doing the drain procedure again as a drain and fill doesn't empty the torque converter. It holds approx. half the fluid so it'll mix with the new stuff.
Old 07-19-2009, 10:52 AM   #3 (permalink)
Refill through the dipstick tube.
