Old 06-16-2008, 07:18 PM   #1 (permalink)
Dardy is on a distinguished road
Default Rear brake drums
Hi my wife has a 2003 aerio sx and im trying to put new brake pads on her car can someone please help me on how to remove the rear brake drum? Thank you
Dardy is offline   Reply With Quote
Old 06-17-2008, 01:00 AM   #2 (permalink)
Not to be smart but
A HAMMER AND USE IT LIKE YOU MEAN IT!!!
Once a Zuk brake drum rusts in place you have a minor problem and you need to break the rust free.
Old 06-17-2008, 06:37 PM   #3 (permalink)
Thanks i did use a hammer like i meant it and all it did was knock the brake dust out of it. I did notice a phillips head screw and the face of the drum does this need to be removed? also what are the 2 8mm screw holes for?
Old 06-17-2008, 08:48 PM   #4 (permalink)
billbon8 is on a distinguished road
The two tapped holes are for jack bolts. These are metric, so make sure you get the correct ones. Evenly turn the bolts and the drum should just pop off. When you put it back on, lightly lubricate the center hub area so that it won't be so hard to remove in the future.
A so called mechanic put cracks in my drums using the hammer method.
billbon8 is offline   Reply With Quote
Old 06-17-2008, 08:50 PM   #5 (permalink)
Also, take out the phillips head screws before using the jack bolts. Those are just retainers for when you reinstall the drum.
Old 06-18-2008, 05:30 PM   #6 (permalink)
Thank you i will give it a try
Old 06-19-2008, 12:15 AM   #7 (permalink)
Sorry about mentioning the screw just figured you would have removed that. But after the screw is removed once you get some movement in the drum from the hammer (so you don't strip out the jacking bolt holes) then use the jacking bolts.
