FYI, the Suzuki contact # is 1-800-934-0934. The keyless remote instructions came as a supplement to the owner's manual. Here is the 10 step procedure:
1. Confirm that all doors are closed and the ignition key is NOT in the ignition cylinder.
2. Open the driver's door and within 10 seconds insert the key in the ignition.
3. Now, within 10 seconds remove the key from the ignition.
4. Within the next 20 seconds, push and release the driver's door switch 3 times. This is the switch near the door strike plate which turns on the inside light and indicates that the door is open.
5. Within 10 seconds, insert the key in the ignition.
6. Now, within 10 seconds remove the key from the ignition.
7. Within the next 20 seconds, press and hold both the LOCK and UNLOCK buttons on the transmitter. Hold both for at least 5 seconds. All the doors will lock or unlock to confirm that procedure was done properly.
8. Within the next 5 seconds after step 7 was complete, press either the LOCK or UNLOCK button to confirm that this process has been properly done. Now, the transmitter has been programmed.
9. Repeat steps 1 to 8 for additional transmitters.
10. Operate each transmitter to verify the programming.
BTW, the supplmental instructions have a Suzuki part number of 99016-54G20-015 (dtd July 2002).
I don't have a scanner at home so emailing these is a challenge. Please let me know how you make out....
Bill
