Originally Posted by billbon8
Hello,
Call the 800 number for Suzuki and they'll send you what you need. I bought remotes and programming from 'keyless ride' before I found the factory ones. The dealership wanted $150 for 2 remotes with programming. Anyway, if I had found the factory remote in time, I could have saved myself $45.00 (from keyless ride).
Bill
Is there something complicated about programming the remote again? All I did was swap out the battery and now the remote doesn't work. I bought the battery from the dealership, wouldn't you think they would have been courteous enough to let me know that replacing the battery would require new programming.
When I had to program my remote for my Hondas it was as simple as turning the ignition key 3 or 4 times then pressing the buttons on the remote and it was programmed..... isn't the process for programming this remote the same since it's the original remote and doesn't require a new control module?
What's the 800# to call? Didn't find one in my owner's manual.
You're telling me if I call them they'll simply send me the instructions for programming without charging me anything?
Wouldn't that be a refreshing change
