Joel,
Before you punt, check if the battery is good. Put a volt meter on it. Probably is one of those 3 VDC thin, watch type batteries. Once you know that the battery is good, try the procedure again (at least tiwce). When I did it, it seemed to require more than 1 attempt to achieve success. Good luck...
Bill
