Originally posted by truck1985@Jan 5 2006, 05:18 PM
My 2003 Aerio CD Changer will not play any cds, and gives me an error code of "3" when I insert one. Any suggestions?
Hi
Because you said "any CDs" it strikes me as a communication problem. This same type of problem drove me nuts when my mom's Altima wasn't recognizing CDs and giving an error code. In the end? Disconnecting the battery for about 10 minutes solved the problem. It's worth a try.
Also, I did a quick search on the web for Suzuki error codes and couldn't find any, however I did come across some GM codes. While they don't have an error code of 3, they do have 23 and 33 for CD players and changers, respectively. I'll just copy/paste what I found, though the battery disconnect/reconnect seems to be the fix. Beyond that, I'd take it to the dealer. Good luck bro.
Keep in mind these are GM explanations, so don't go to a ACDelco center, heh:
E23 : Communications Error Cause(s): There is a vehicle/radio communication problem or an internal radio communication problem. Correction(s): Disconnect battery voltage to the radio and then reconnect after a few minutes. If there is still an error, send the unit to an ACDelco® Service Center.
E33 : CD Changer Communication Error Cause(s): There is a vehicle/radio communication problem or internal radio communication problem. Correction(s): Disconnect battery voltage to the radio and then reconnect after a few minutes. If there is still an error, determine if the problem is with the radio, the harness or the changer. Inspect for correct voltage at all connectors. If there is still an error, service the unit at an ACDelco® Service Center.
EDIT: To comply with the forums plagarism guideline, those quotes were by buickmania on carforums.net.
