FYI,
The windshield recall is the paint recall. The windshield is glued to the paint, so if the paint does not adhere, the windshield might pop out in an accident.
If your car was actually defective, you would have noticed it in 2002-2003... the paint would come off in big junks while just washing the car. If you stuck a strip of masking tape on the paint, all of the paint down to the primer would come off when the tape is removed.
In Canada, the dealers have a list of the specific VIN's that are effected, and which dealer took delivery of the vehicle.
Your dealer can run your VIN to see if the recall applies. If it does, the dealer will do a scratch test on the cowl under the plastic trim at the base of the windshield. A cross hatch pattern will be cut into the paint using an razor knife, a strip of special tape will be placed over the scratched area, then removed. Based on how much paint comes off with the tape, the dealer will know if the paint is defective. If the paint is ok, the dealer will seal up the area where the test was done to prevent corrosion.
Tim
