Old 05-03-2005, 09:45 AM   #1 (permalink)
ChillinSX04
Here's the basic info that I got for free from suzukipitstop.com I'll make it all prettier later but for now it should be enough I figure.
Aerio 04 01315 Correct Torque Converter Bolts 2002-2006 1/31/2005 General 02 12164R Programmable Keyless Entry System 2001-2002 12/16/2004
Aerio 06 12144 Driver and/or Passenger Side Mirror Loose 2002-2004 12/14/2004
General 05 11094 Service Manual Update for DTC P0420 and/or (P0430 V6) Inspection and Troubleshooting 1996-2005 11/9/2004
General 04 10214 VIN# Registration After ECM Replacement 2005-2006 10/22/2004
Aerio 05 10124 Service Manual Update Headlight installation 2002-2004 10/12/2004
Aerio 03 07084 Service Manual Correction Tightening Torque of Gear Shift Interlock Bolt 2004-2004 7/8/2004
Aerio 01 07084 Bevel Pinion Mounting Distance (AWD) All Years 7/8/2004
Aerio 03 06304 Alternator Replacement 2002-2004 6/30/2004
Aerio 02 06284 Left Drive Shaft Pops Out 2002-2004 6/28/2004
Aerio 04 05174 Instrument Cluster Bulb Replacement 2002-2004 5/17/2004
Aerio 02 05074 Aerio Front Brake Pads 2002-2004 5/7/2004
Aerio 01 032904 Service Manual Update Manual Transmission Assembly Procedure 2002-2003 3/29/2004
Aerio 01 02274 Slow and/ or Incomplete Retraction of Seat Belts All Years 2/27/2004
Aerio 02 01074 Correct Coolant Usage 1986-2004 1/7/2004
Aerio 01 10173R Tech 2 PCMCIA Card Re-Flash Update All Years 9/30/2003
Aerio 02 07113 Service Manual Update - EVAP Inspection Procedure 2002-2003 7/11/2003
Aerio 03 06253 Safety Recall Campaign; EC FM VSS 212 Windshield Mounting 2002-2003 6/25/2003
Aerio 02 06203 Windshield Washer Hose Updated Part Number 2002-2003 6/20/2003
General 03 05073 Rear Main Oil Seal Installation Tools 1999-2003 5/7/2003
Aerio 02 03273 Popping Noise on Slight Turns 2002-2003 3/27/2003
Aerio 01 02103 Service Manual Update - Rod Bearing 2002-2003 2/10/2003
Aerio 01 02033 Service Manual Update 4WD Alignment Specifications 2003-2003 2/3/2003
Aerio 01 013003 Electrical Noise on AM Stations 2002-2003
Aerio 01 12192R Revised Metallic Clacking/Clicking Noise When Applying Brakes 2002-2003 12/19/2002
General 02 12112 Engine Tick Noise 1999-2003 12/11/2002
General 01 02252 Technical Service Bulletin System Revision All Years 2/25/2002
General 10-1 04210 Air Bag On/Off Switch Installation Instructions 1995-2003 4/21/2000
ChillinSX04 is offline   Reply With Quote
Old 05-03-2005, 02:51 PM   #2 (permalink)
ShortBuSX
Thats nice to have around, very useful info!
<img src="http://www.suzuki-forums.com/images/....gif">
ShortBuSX is offline   Reply With Quote
Old 05-13-2005, 02:58 AM   #3 (permalink)
ChillinSX04
Just found out this info is available for purchase at suzuki and www.alldata.com/recall
