» Sponsor Links
»Garage Storage and Cabinets
Go Back   Suzuki Forums: Suzuki Forum Site > Technical > Suspension, Wheels and Tires
Old 08-03-2005, 11:47 AM   #1 (permalink)
sumerlin
I had tires replaced and now my low tire light is flashing on an 05 Verona. I understand there should be a reset procedure to correct this situation.
Does anyone know how this is done?
I hope I dont have to go to the dealer as there is not one real close to me.
sumerlin is offline   Reply With Quote
Old 11-11-2005, 06:31 AM   #2 (permalink)
dan_e
Thumbs up
161 views and no responses? Have a 2005 XL-7 and cant reset my light either, was looking for some help.
dan_e is offline   Reply With Quote
Old 11-09-2007, 06:38 PM   #3 (permalink)
eaa9mm's Avatar
eaa9mm is on a distinguished road
Default Tpms
I am having the same problem . The low pressure warning light seems to start flashing after I have driven a while and the tires are well heated up. I got an instruction sheet from a tire dealer but it refers to "the driver side door switch hand" which you have to push on and off several times to reset the sensor . But I have yet to figure out what the "driver side door switch hand is !! Either this or buy the Tool which probably costs $$$$$ .
eaa9mm is offline   Reply With Quote
Old 11-24-2007, 03:40 PM   #4 (permalink)
eaa9mm's Avatar
I have also found that all service parts should be replaced every time the tire is dismounted. My 2006 XL-7 uses a Schrader model. Information for what make and model your system uses try The Tire Rack - Your performance experts for tires and wheels and find the link to the TPMS. The service kits are also listed there. The service kits consist of a rubber grommet, an aluminum retaining nut, a special nickel- plated valve core and an O.E. valve cap.
