Old 04-18-2009, 06:51 AM   #1 (permalink)
JCJC is on a distinguished road
Default how to change brake pads
can i get instruction on how to change the brake pads
thanks for any help
JCJC is offline   Reply With Quote
Old 04-18-2009, 01:00 PM   #2 (permalink)
pyaaw!'s Avatar
pyaaw! is on a distinguished road
thanks for any help
Give me a few hours and i can get some pics up for you.
pyaaw! is offline   Reply With Quote
Old 04-18-2009, 10:28 PM   #3 (permalink)
pyaaw!'s Avatar
I don't know how mechanically inclined you are so i will try to make this as simple sounding as possible. So please don't feel disrespected. and pics are from the passenger side front.
Tools required: 3/8" drive ratchet, 3/4" socket, 9/16" socket , 3" 3/8" drive extension, and a medium size clamp.
Step one----
Take the hub caps off the rims, and loosen the lugnuts.
Step two--
jack up the car, put a jack stand under the car don't rely on the jack to hold the weight for a sustained period, i have seen them drop cars before.
Step three--
take off the lug nuts and remove the wheel. you will see this
Step four-
There are two bolts on the back side of the brake caliper, use the 9/16" socket. the top bolt is seen here
The lower bolt seen here
Step five--
Remove the caliper, set it off to the side, but don't let it hang by the brake hose. seen in the center of the picture.
and here
Step six--
remove the pads by pulling on the top side of the pad and sliding it out.
Step seven--
Remove the retaining clips by pushing on the outer sections of the clip away from the housing.
****I am not replacing my pads so i did not pull off my clips. and did not need to use the clamp so i did not get a pic of it cuz i forgot about it til now****
Step eight--
Install new retaining clips. add some anti seize to the clip where the pad sits. it will keep the pads from squeaking.
Step nine---
install pads. bottom first, basically the opposite of how you pulled them off.
Step ten---
Use the clamp to push in the brake piston in, until it is able to fit over the rotor. The piston is in the center of the part taken off in step five.
Step eleven--
Install the brake caliper. install the 2 bolts.
Step twelve--
Install the wheel and lug nuts. lower the car, tighten the lug nuts.
Step thirteen-- IT IS VERY IMPORTANT THAT YOU PUMP THE BRAKES UNTIL THEY ARE STIFF. other wise you will not be able to stop because the pads are too far from the rotor.
let me know if you got any questions.
Old 04-19-2009, 09:06 AM   #4 (permalink)
thanks all i needed to know
thanks again
Old 04-19-2009, 12:46 PM   #5 (permalink)
pyaaw!'s Avatar
thanks again
no problem
Old 07-31-2009, 04:53 AM   #6 (permalink)
kurtdaniel is on a distinguished road
that was a nice instruction..for additional info on how to change brake pads..If this is your first time doing this, allow 3-5 hours, especially if you are by yourself and using hand tools. Obviously a buddy and air tools will make things go faster. I changed mine in slightly over 2 hours, and this is the first time I have. My time estimate of 3-5 hours may be very generous, but it's important that you are not rushed.
kurtdaniel is offline   Reply With Quote
Old 08-10-2009, 11:15 PM   #7 (permalink)
spcolsson is on a distinguished road
how about the rotors i know you do the hole removel of the brake pads but from there is it just the 2 set screws on the rotor face or is there more thinks
spcolsson is offline   Reply With Quote
Old 08-11-2009, 01:26 AM   #8 (permalink)
tallkid's Avatar
usually rotors just pull off. they aren't held on by anything but the lug nuts, which you took off when you took the wheel off...so it should just come off after the caliper comes off.
tallkid is offline   Reply With Quote
Old 08-11-2009, 05:23 PM   #9 (permalink)
ok sweet i think i hade one if not 2 wourped rotors in the rear and i need to replace them but ive never done anything like that lol and as for how mechanickly inclined i am i work on ah-64d's for a living there atack helacopters so im hoping i can figer it out lol
Old 09-04-2009, 05:07 AM   #10 (permalink)
Quaker is on a distinguished road
I tried to remove the caliper and once it gets to a certain point, the caliper gets stuck and won't come off.
Anyone with ideas?
Quaker is offline   Reply With Quote
