Originally Posted by OhNoReNo
anyone know where i know where i can get a sway bar for the reno? i have a 2007
Yep! They're $299 for front and rear kit.
http://i192.photobucket.com/albums/z...MSswaybars.jpg
Description:
The BMS Suzuki Reno/Forenza features CAD designed sway bars for optimum fit and function. Bars are precision bent, using computer controlled hydraulic benders. Performance is the name of the game with these sway bars. Because stock sway bars are mediocre at best, it was important that this anti-sway system be designed to plant the tires to the ground and provide maximum performance, traction, and handling without compromising passenger comfort. BMS has designed sway bars for multiple racing applications and environments. Bar designs allow for both understeer and oversteer as the case requires. All sway bar kits include urethane bushings as well as all mounting hardware and connecting rods. Rear sway bars can be installed by the novice mechanic. Front sway bars should be installed by a professional mechanic, since the subframe must be lowered for installation (in Reno and Forenza applications). BMS can install and tune this sway bar kit upon customer request.
You can get them through me, just email me at
Danny@KinkyMotorsports.com
