Originally Posted by kickbike
so you are saying :the 18" X 7 or 7.5 using (195/205/215)/35/18 Tires Would fit without rubbering anything on our cars? sorry for the recap, But I think it would be cool to not have more ambiguity in the subject and a statement is post to new and old readers searching in the 18 Wheels installation.
Yes..if you get the right offset. What I'm saying is the width is what changes what offset you need for the fitmit. For example 7.5" wide (weather it be a 15, 16, 17, or 18" wheel) offset is
probably best at around +45 while a 7" wide wheel (weather it be 15, 16, ect) offset is
probably best at around +40. The offsets that I just stated are either damn close or dead on for fitmit...but I can't be sure.
With 1.6" drop or less the biggest wheel tire combo you could go is a 18x7.5 w/ a 225/35/40 tire. At this fitmit you're offset will proabbly have to be dead on perfect for no rubbing. Also it is probably possible to fit a 8" wheel but that would require some test fitting or good calculations to figure out what would work.
