Originally Posted by kinkyllama
I think he is using the stock tires. It will make the sidewall harder if you go wider on wheels...to a point. Think of it this way, a really wide tire on a smaller wheel will give it sloppy turn-in because the sidewalls almost hanging off. A smaller tire on the same wheel and your turn-in and response will improve because the sidewall has more support.
I have them on now and they have given me two major benefits:
1) The offset has allowed for slightly more outer exposure, so my track-width has improved just from that alone
2) The tire is virtually flush with the wheel, if not slightly more bulge exposed to protect the edge (bonus)
To add more to the conversation on the sidewall, you've already explained the majority of the points; even more simple, by widening the bead placement on the wheel, you are reducing the length of lateral travel from the flex of the sidewall. The drawback is in the wear because the tire is originally designed with a particular contact patch width in mind with the appropriate wheel. I now have to set my pressure at 30 lbs. for even wear while still wearing this tire. When they are done, I'll likely move up to a 205 width tire with this wheel. I think 215 will probably be pushing it.
