» Sponsor Links
»Garage Storage and Cabinets
Old 06-30-2006, 08:28 PM   #1 (permalink)
EboniOne85 is on a distinguished road
Default tires
I hate the gap between the tire and the car. Whats the largest size tires I could put on my '06 Forenza or is there any other way i could get rid of that gap?
EboniOne85 is offline   Reply With Quote
Old 06-30-2006, 11:56 PM   #2 (permalink)
Danny is on a distinguished road
You dont want to get bigger tires, that'll change alot. It'll make your speedometer wrong, change gearing, hurt performance, and hurt gas mileage.
Lowering springs will lower your car up to 1.5" all around (I recommend apex springs) or for alot more money and better performance KW coil-overs and you can lower the car as much as you want.
I'm using this account untill I can get back on my other one. -Kinkyllama
Danny is offline   Reply With Quote
Old 07-01-2006, 12:26 AM   #3 (permalink)
masterbiscuit's Avatar
masterbiscuit is an unknown quantity at this point
+1 to Danny's post.
You want to lower the car, not fill in the space with empty rubber. Bigger rubber is for off road (and hot rods). For street and performance, you want a smaller sidewall on the tire, which means lower profile. Slightly larger rims with slightly lower tires and MUCH lower springs will make a nice difference.
I agree with Danny, (not that he said it here, but) I love the look of wheels tucked in behind the fender.
The END of Florida!
masterbiscuit is offline   Reply With Quote
Old 07-01-2006, 12:22 PM   #4 (permalink)
atdewey's Avatar
atdewey
You could spend $400-500 on bigger tires or go with lowering springs for not much more $. The biggest problem with up sizing the tires is the speedometer and ABS if you have it. Going from the P195/55r15 to a P205/60r15 would give you another 1.25" in diameter. That makes your speedometer off by 6%. When it says you are going 60mph you would be going 64. That difference in wheel speed can confuse the ABS computer also. All in all it is not recommended.
The Forum Lounge
atdewey is offline   Reply With Quote
Old 07-01-2006, 02:36 PM   #5 (permalink)
kas
kas's Avatar
kas is an unknown quantity at this point
Drop it!!!! I dropped mine... Got rid of that stupid gap... I put 17's on her and a 1.5 drop all around... I got the Intrax springs....
kas is offline   Reply With Quote
Old 07-02-2006, 04:06 PM   #6 (permalink)
Zipper's Avatar
Gallery: 28
Originally Posted by masterbiscuit
+1 to Danny's post.
Ok, I have not installed my Apex springs, so this comparison is all rim
Before
After
The look alone in the gap changed with the different rims, but my over all diamiter is the same.
I know black on clacks hard to see
Old 07-02-2006, 07:34 PM   #7 (permalink)
It will be better to drop the car like others have said than to put on bigger tires, especially when you don't have mods on the car to power the bigger tires.
Old 07-04-2006, 05:56 PM   #8 (permalink)
thanx again guys.
Old 07-04-2006, 07:18 PM   #9 (permalink)
thanx again guys.
I'm selling my lowering springs on ebay now. Item #: 110004123236
Old 07-16-2006, 10:51 PM   #10 (permalink)
Blue_Forenza
I dont understand, increasing the size of the rubber makes the diameter bigger right? its the same when you put 17" rims, it increases the diameter right? so its better just to have the stock size rims and tires and just drop the car???? wont dropping the car ruin the tie rod, sispension bushing, etc?
Blue_Forenza is offline   Reply With Quote
