» Sponsor Links
»Garage Storage and Cabinets
Old 07-17-2006, 12:04 AM   #11 (permalink)
Zipper's Avatar
Gallery: 28
Originally Posted by Blue_Forenza
I dont understand, increasing the size of the rubber makes the diameter bigger right? its the same when you put 17" rims, it increases the diameter right? so its better just to have the stock size rims and tires and just drop the car???? wont dropping the car ruin the tie rod, sispension bushing, etc?
My Rims are 17", but the wheel as a whole is the same diamiter as the stock. This keeps my Odomoter, and spedomoter in check (Making the over all size larger or smaller will mess up the reading the odomoter and spedomoter shows)
WHat he means by dropping the car is to use a different spring set. With the McPherson set up the forenza/reno has, the spring is a coil that is over the strut, AKA a coil over. All we would do is use shorter springs.The car as a whole lowers 1.5 inches. Not a big drop in anyones book.
Old 07-17-2006, 12:17 AM   #12 (permalink)
masterbiscuit's Avatar
masterbiscuit is an unknown quantity at this point
Bigger tires on the same rim will throw off the speedo/odo. It will take less turns for the wheel to travel the same distance on the road.
Bigger RIMS are usually offset with lower tires. And like Zipp says, the overall diameter stays the same. So nothing gets thrown off.
The benefit to more rim/less tire is a tighter grip on the road, due to smaller sidewalls. It also looks better (at least in most people's books...heh).
Dropping the car with shorter springs shouldn't harm the tie rods or bushings. Think about it like this. When you weigh your car down with people/stuff, it can very possibly drop 2 inches or more. The car is designed to do this already. So you're just making that drop permanent.
The worry here would be that when you weight it down again, it'll drop TOO far for the tie rods, bushings, etc. BUT, usually the lower springs are much stiffer to prevent that from happening.
Generally, you can drop the car up to 2 inches with good stiff springs and the rest of the suspension will be fine. Just make sure you don't wind up with tire rub.
I had thought of keeping the rims I have (again, I actually happen to like the mags that came with the car) and just go with a thicker tire. Screw the speedo, I'm fine with that. But I realized that if this is done, I will lose acceleration. It's like chaging to a higher gear on a 10-speed bike or the like.
Now, Dog had mentioned going smaller. This would increase acceleration. Either going down to 14" rims or using a lower profile tire on the 15's would do the trick. It's not a huge difference mind you, but every little bit helps, right?
The END of Florida!
masterbiscuit is offline   Reply With Quote
Old 07-17-2006, 01:59 AM   #13 (permalink)
kinkyllama's Avatar
Dropping the car +/- 1.5" won't hurt a thing. I have mine dropped somewhere around 3" front and back... probably more.
Ebay store:
Myspace:
