Originally Posted by Dj Low Proz
i dont know the specs says the kia would beat us, but it all comes down the drivers.
Heres the specs from MotorTrend:
-1,975 cc 2 liters in-line 4 front engine with 82 mm bore, 93.5 mm stroke, 10.1 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
- Power: 103 kW , 138 HP SAE @ 6,000 rpm; 136 ft lb , 184 Nm @ 4,500 rpm
- Curb weight: 2,892lbs
Against:
- 1,998 cc 2 liters in-line 4 front engine with 86 mm bore, 86 mm stroke, 9.6 compression ratio, double overhead cam and four valves per cylinder
- Power: 95 kW , 127 HP SAE @ 5,600 rpm; 131 ft lb , 178 Nm @ 4,000 rpm
- Curb weight: 2739lbs
