Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > Suzuki Forenza & Reno Forum > Street Encounters & Competition Racing
Old 02-12-2007, 10:51 AM   #11 (permalink)
jaxreno's Avatar
jaxreno is on a distinguished road
Originally Posted by kinkyllama
I recommend any organization other the SCCA...I've had more problems the few times I've run with them than anyone else.
2ndly miatas seam to make horrible drift cars...I've seen several very experiance drivers try to drift miatas and still haven't seen one do it yet. The cars were set up for roadracing but so are alot of the 240s I see out there drifting.
The main problems I have seen with Miatas are that people do not seem to know how to properly set up the suspension. I have personally driven one that was set up absolutely perfectly. Of course he had tons sunk into the suspension.
Once I start setting mine up, it will be all out. I plan on stitch welding the entire chassis, filling all rails and pillars with expanding foam, and reinforcing all stress areas of the frame. I will also be custom installing a full cage.
Another thing is with installing a 13B if done properly is that all the weight is placed behind the front axle and down low. Instantly that in itself makes the car handle great by effectively lowering the center of gravity and evening the weight distribution. Once everything is fabricated and installed and I have put put in some quality coilovers, I will have the car corner balanced. Of course all other suspension mods will be made, braces, strut bars, sway bars,etc. I don't believe I will make any engine mods for a while, just focus on suspension and tightening the car up.
"Oversteer is when the passenger is scared; understeer is when the driver is scared!!"
"Thats why you can't hit 120. Get a set of better tires with a high enough speed rating and you should hit it." -Jurupa
jaxreno is offline   Reply With Quote
Old 02-12-2007, 01:42 PM   #12 (permalink)
kinkyllama's Avatar
I know the drivers of the miatas had the cars setup very well for roadracing, not drifting...but they still couldnt get the back ends out worth a damn. Two 240s setup for roadracing(again, not drift) with only 130hp were getting the rears out beautifuly. It could have been the drivers of the miatas but still I've seen several trying to drift and none have done well.
Ebay store:
Myspace:
Old 02-14-2007, 09:39 AM   #13 (permalink)
dog
dog's Avatar
dog is an unknown quantity at this point
Its the front/back wieght distribution in the miatas 50/50. Not a hell of alot of power but in the twisties Miatas rule.
dog is offline   Reply With Quote
