First of all what kind of sensor does your vehicle have? MAP, MAF? If you can tell me what kind it has I can tell you how to set it up. Also check with a multimeter to see what the voltage output is at zero throttle and at WOT.
"Oversteer is when the passenger is scared; understeer is when the driver is scared!!"
"Thats why you can't hit 120. Get a set of better tires with a high enough speed rating and you should hit it." -Jurupa
