It does sounds like a tune up issue. start by taking out the spark plugs an checking their condition. Also take off the air intake hose from the throttlebody and see if there is oil in the hose and in the plenuem(check that by moving the throttle cable) if you have excessive oil you will need to do spark plugs, pcv valve,clean oil out of intake hose, and have the throttlebody cleaned( induction service). Also need to check if the map sensor is clogged with carbon, if so get a new one from the dealer its been update. If after all that is done and it doesn't fix the problem then you could have a head problem, catalytic converter problem and or need an engine at worst case. Remember that car has a 7year/100000mile drivetrain warrenty that transfers from owner to owner. The pcm(computer) and catalytic converters are 8year/80000miles. I know this is alot but you need to know this. Good luck and let us know how it goes! Almost forgot get a compression test done normal for each cylinder is 185 to 200 psi.
Reason: forgot to add additional info.
