Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > Suzuki Forenza & Reno Forum > Interiors & Exteriors
Old 06-29-2008, 01:30 AM   #1 (permalink)
pyaaw!'s Avatar
pyaaw! is on a distinguished road
Question ecm reset.
Hello everyone,
I have an '08 renza
I have found a few threads that tell you to disconnect the ground and push the brakes/or turn on the headlights. well if you disconnect the ground the lights will not turn on. so how do you really rest the ecm?
pyaaw! is offline   Reply With Quote
Old 06-29-2008, 02:26 AM   #2 (permalink)
Gallery: 11
your supposed to disconnect the batery and step on the brakes to drain out the stored power
Old 06-29-2008, 09:48 AM   #3 (permalink)
pyaaw!'s Avatar
this is exactly what i did, so you can tell me if i did it wrong.
1-disconnected the battery(ground)
2-held the brake pedal (did not see my brake lights on, at all)
3-waited 15-30 minutes
4-reconnected the battery
5- started the car, did not see the speedo jump up to 70mph, like someone said
then,
to be sure i fully disconnected the battery and did steps 2-5. but i waited about 3 hours, this time. still no speedo jump.
also i noticed my radio kept the all my presets, does that mean anything?
thanks ahead of time for the help
Old 06-29-2008, 11:49 AM   #4 (permalink)
Gallery: 11
i think you have to disconect the pos cable. i dont have the link to the thread right now
Old 06-29-2008, 12:32 PM   #5 (permalink)
Zipper's Avatar
Gallery: 28
radio has capacitor to help keep the presets.
When I reset mine, it never jumps
Old 06-29-2008, 12:58 PM   #6 (permalink)
When ever I reset my ECU my speedo jumps to 60 and stays there for a sec or two and drops. My radio presets also go away. But then again I believe the 05 Reno's have a different radio than the 04 and 05 Forenza's. I don't know about 06+ tho.
Old 06-29-2008, 01:52 PM   #7 (permalink)
pyaaw!'s Avatar
ok thanks everyone. i guess i will have play with it to see if i can find anything different to show it has been reset.
Thanks again
Old 07-14-2008, 10:08 PM   #8 (permalink)
phatslaya is on a distinguished road
Ok. So i've reset my ECU a few times by taking the ground off. It has seemed to work everytime so this time after reading the forum i decided why not take the positive off and see if it does the whole speedometer reading and what not. Well after i took the positive off, I now have a check engine light :@. Guess ill have to take the car to the dealer so they can take the CEL away.
phatslaya is offline   Reply With Quote
Old 07-14-2008, 10:44 PM   #9 (permalink)
Thats a good way to short out the car assuming you are leaving the negative side on.
Old 07-14-2008, 11:01 PM   #10 (permalink)
Oh shit. What does this mean ?
