Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > Suzuki Forenza & Reno Forum > Interiors & Exteriors
Old 06-16-2008, 07:30 PM   #1 (permalink)
bigbadmarine06 is on a distinguished road
Default Dash accent removal
ok heres my question...
how do i take off the silver accent pieces on my dast and doors in my 07 reno? i want to remove them and redo them in a different color or in carbon fiber. ill attach a picture so you know what im talking about
bigbadmarine06 is offline   Reply With Quote
Old 06-17-2008, 12:46 AM   #2 (permalink)
Gallery: 11
do a search theres a post with directions on how to do it
Old 06-25-2008, 05:10 PM   #3 (permalink)
jkbreazeale is on a distinguished road
The ones on the steering wheel are easy to remove, taking a small flathead and wiggling those out... if it is like the forenza, you have to remove your glovebox to correctly get the ones above it off. (or be like me and find that out after the fact) the center console piece has some snaps that you just take the flathead to and go from there... here is a picture of my forenza after the end result.
jkbreazeale is offline   Reply With Quote
Old 06-25-2008, 06:31 PM   #4 (permalink)
Forenza Owner's Avatar
Forenza Owner is on a distinguished road
Wow thats awesome.
Forenza Owner is offline   Reply With Quote
Old 06-25-2008, 07:09 PM   #5 (permalink)
pyaaw!'s Avatar
pyaaw! is on a distinguished road
jkbreazeale that looks great! +1 to you great idea
pyaaw! is offline   Reply With Quote
Old 06-26-2008, 01:04 AM   #6 (permalink)
Jet-Lee is on a distinguished road
The center piece that surrounds the head unit, has some reliefs at the top under the vents. Stick a skinny but stout flathead between the plastic and vinyl, and pop it out. It'll take some force, don't be scared.
Don't forget to disconnect the a/c controls from either side of the tunnel.
Jet-Lee is offline   Reply With Quote
Old 06-26-2008, 07:00 PM   #7 (permalink)
Thanks, it took some time, but I got it done... if your Forenza/Reno/Whatever Else you drive is blue... I got a pretty close paint match from Lowe's Home Improvement.
Use the Rustoleum Automobile Primber (Light Gray) 2081
Then Use Rustoleum Metallic Cobalt Blue Metallic Paint 7251
Then Use Rustoleum Crystal Clear Enamel 7701
Depending on Humidity and temperature wait 15 to 20 minutes between stages. The hardest part is removing the cables that attach to the climate controls. There are two of them one on the driver and one on the passenger, if you have a small enough flat head you can get inbetween the the wire and the gears on the back side of each cable or you can take a small phillips head and unscrew from the beginning towards the knobs on each side and go from there (recommended). This project will make you angry, but it is worth it.
Old 06-26-2008, 09:44 PM   #8 (permalink)
Gallery: 11
on the reno you can just pop the cable off the gear then there is a little lever that holds it in place(2 or so inches before the gear) pop it (one on each side) and the front pulls right out
