Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > Suzuki Forenza & Reno Forum > Interiors & Exteriors
Old 06-18-2008, 11:07 PM   #21 (permalink)
Forenza Owner's Avatar
Forenza Owner is on a distinguished road
I am thinking about buying the bulbs from street glow. But to be on the safe side. Those are 55w right? Also to put the bulb in, do I just unscrew the black cover leading to the stock h7 light?
Forenza Owner is online now   Reply With Quote
Old 06-19-2008, 12:46 AM   #22 (permalink)
darkpoet25's Avatar
darkpoet25 is on a distinguished road
You can get them in a 55 watt bulb. All you have to is remove your dust caps and the bulb is easily replaced.
darkpoet25 is offline   Reply With Quote
Old 06-19-2008, 07:05 AM   #23 (permalink)
I went ahead with street glow. I didn't quite trust the other webistes. But anyways I ended up getting the 70w H7. I'm sure the wiring harness can take that. Also I always use my low beams for night driving so it should be ok.
Any thoughts about it?
Ok, I think I'm retarded but,
Unscrewing dust cover, easy.
Try to get the light out, hard. How do you get it out of there? I tried twising and pulling. No luck. argh.
Old 06-19-2008, 09:51 AM   #24 (permalink)
darkpoet25's Avatar
The 70 Watt bulbs should be fine. There is a little metal tab holding the bulb in place, you just have to push it in and move it out. The bulb should pop out fine after that, then you just unplug the wiring and then line up the new bulb, put the metal tab back on and you are done.
Old 06-24-2008, 07:24 PM   #25 (permalink)
Hmmm, well I replaced the driver side with the new bulb with no problems.
However, I tried doing the passenger side and I was able to get the bulb out, but the metal tab holding it came out with it too.
I am going to call and have my local auto tire put it back in. Did I break anything?
Old 06-24-2008, 08:21 PM   #26 (permalink)
darkpoet25's Avatar
It should be easy to put the tab back on. Since you don't have a picture I can't say for sure though. Sorry to hear about it happening.
Old 06-24-2008, 08:44 PM   #27 (permalink)
Yeah the the whole metal part came out. Oh well. At least I have one side.
Old 06-24-2008, 11:57 PM   #28 (permalink)
kinkyllama's Avatar
Hmm, I think it's just held on by a screw.
Just remove the whole headlight. There are two (10mm I think, maybe 12mm) bolts on the top and one hidding near the grill on the side, you reach it from the engine bay. I think that's it but it's been awhile since I've had a forenza front end.
Ebay store:
Myspace:
Old 06-27-2008, 12:09 PM   #29 (permalink)
I took it to the dealer, so that way I won't have issues doing it myself. Also you are correct in that the tab is held on by a screw.
Other than that, I love the lights.
