Electric Fan Sensor/Switch location?
2006 Reno 95,000 miles: recently getting hot. The fans don't seem to be running. I have spent the last 2 hours searching here and the web with no luck. Can anyone tell me where the fan switch/sensor is? I want try to replace that to see if it cures the problem of it running hot. The water pump pulley is tight, the thermostat seems to be working as I can get heat to run inside the car. Description or pictures would be fantastic. Thanks gang!
Rob
