Replacement Thermostat - Suzuki Forums: Suzuki Forum Site
Old 02-02-2011, 01:32 PM   #1 (permalink)
Mario is an unknown quantity at this point
Default Replacement Thermostat
Has anyone here been able to find a suitable aftermarket replacement?
Mine been too lazy to completely close and currently running @160F... plus heating sucks for winter.
I'm about to call the dealer for this, but have been told it could run around 120$ because you need to buy the entire thermostat assembly PLUS a separate gasket.
I found the guy on ebay that seem to be popular here, but adding custom charges to this make that solution possibly expensive.
Rockauto has the Beck/Arnley replacement (Thermostat/Housing/Gasket) priced @30$ (plus 25$ shipping), but no need to care for additional customs charges.
Has anyone even tried to go the cheapest way and replace the thermostat only (<10$)? I fear once the housing is removed, that the new part doesn't fit well.
Mario is offline   Reply With Quote Quick reply to this message
Old 02-02-2011, 10:38 PM   #2 (permalink)
SUZUKI NUT is on a distinguished road
Cool Thermostat
What kind of car do youhave?
SUZUKI NUT is offline   Reply With Quote Quick reply to this message
Old 02-03-2011, 07:58 AM   #3 (permalink)
Sorry, forgot to specify and it seems my profile (at left) doesn't contain the info anymore.
Chevrolet Optra 2005.
I use the Suzuki Forenza 2005 to check for parts compatibility since almost no one what an Optra is...
Old 02-03-2011, 09:53 PM   #4 (permalink)
Cool thermostat
Advance auto parts show a 190 degree thermostat for 2005 forenza s
Part no. 48619 you might try them.
Old 02-04-2011, 01:04 PM   #5 (permalink)
Unfortunately Advance Auto Part doesn't ship outside USA.
I called my GM dealer and as expected:
-Thermostat and Housing cannot be sold apart. So it's 114$
-Gasket isn't included... so it's 15$ more.
(Yup, Canadian dollard is over parity, but we we're still getting screwed over auto parts prices...)
*The thermostat is also on national back order with no availability date specified...
So I ordered the Beck/Arnley one from RockAuto. Could have been cheaper, but since shipping is already 30$, I decided to take the one that seemed the safest bet (Thermostat/Housing/Gasket in the same box). I also added a few parts that will need my attention in the next few months like ignition wires and a serpentine belt.
I'll let you know how it turns out.
Old 02-19-2011, 07:38 PM   #6 (permalink)
Last Follow-Up on this.
Received the Beck/Arnley part. Was in fact a Motorad, made in Germany, that has the same exact specs as the one sold on eBay. Guess it has to be the same.
I had a leak around it on my 1st install... so I did the job again.
This time:
-Sanded the new part where it has to contact the block. The finish was a bit to rough.
-Sanded the block to remove some rust/gasket leftovers
-Added a tiny bit of black RTV under and over the gasket (The used OEM one showed signs of RTV residue on it).
This time, no leaks... and the temp gauge is back to normal. I also get goot heating again!
Weird thing is, from looking carefully at the OEM part, I cannot understand how you could get a good fit buying only the thermostat. Unless the pictures I get are not the right ones on parts sites.
Old 02-22-2011, 01:36 PM   #7 (permalink)
Gallery: 11
you cant buy just the thermostat it only comes with the housing.
Old 02-23-2011, 08:17 AM   #8 (permalink)
Totally makes sense to me... but it got me thinking when I saw all those cheaper alternative on RockAuto website that included ONLY the thermostat.
I guess you stick them there using only RTV and hope it doesn't fall loose ;-)
Old 06-01-2011, 07:38 PM   #9 (permalink)
Sithrico is on a distinguished road
So would you say to go with the ebay one? I need to change mine and was wondering if I could buy the inexpensive thermostats only also. Sounds like you solved my situation. What kind of RTV did you use also. Hi temp or just the normal?
Sithrico is offline   Reply With Quote Quick reply to this message
Old 06-03-2011, 07:55 AM   #10 (permalink)
I used ordinary black RTV... it said on the package that it was OK to use pour cooling system parts.
Compare the eBay price including shipping vs Rockauto. Depending where you need to ship, one might be cheaper than the other. In Canada, Rockauto made more sense, plus I added a few more parts in the cart that I needed too.
