P0342 Camshaft Position Sensor - where is it? - Suzuki Forums: Suzuki Forum Site
Old 01-30-2011, 06:06 PM   #1 (permalink)
Kevin108 is on a distinguished road
Default P0342 Camshaft Position Sensor - where is it?
He guys, I'm wrenching on my GF's 04 Foreignza which is throwing a code for the CPS. Where is it located and what do I need to do to replace it?
Also, do these cars having timing chains or timing belts? My 00 Jeep Cherokee was tossing codes for the cam and crank sensors but it just needed the cam sensor reindexed. (Apparently it's possible for the timing chain to stretch more than the computer can compensate for things and it gets to a point where you have to find TDC, zero out the timing and line up two holes in the CPS and the housing it sits in.)
Any help you guys can offer would appreciated. I'm thinking we're at a point with this car where I'll be here fairly regularly.
1987 Chevrolet Silverado
2000 Jeep Cherokee
2004 Suzuki Forenza
Kevin108 is offline   Reply With Quote Quick reply to this message
Old 01-30-2011, 06:15 PM   #2 (permalink)
Forenza Owner's Avatar
Forenza Owner is on a distinguished road
Hi there,
I do not where the CPS is but this car has a timing belt.
Forenza Owner is offline   Reply With Quote Quick reply to this message
Old 01-30-2011, 09:01 PM   #3 (permalink)
How many miles is a timing belt good for? Can the timing belt stretch and cause a false camshaft sensor code?
2000 Jeep Cherokee
2004 Suzuki Forenza
Old 01-31-2011, 09:20 PM   #4 (permalink)
24 hour bump.
2000 Jeep Cherokee
2004 Suzuki Forenza
Old 02-01-2011, 04:30 AM   #5 (permalink)
Gallery: 11
they say to change the timing belt at 60,000. i dont think the belt can stretch and cause a code i believe it has an auto tensioner. the cps is located on the top passenger side of the valve cover in between the cam gears. heres a link to a manual.
Daewoo Service Manual
Old 02-01-2011, 09:02 PM   #6 (permalink)
Thank you for the info and especially for the link!
2000 Jeep Cherokee
2004 Suzuki Forenza
Old 02-01-2011, 11:39 PM   #7 (permalink)
Gallery: 11
sure no problem. good luck
Old 02-02-2011, 02:20 PM   #8 (permalink)
Mario is an unknown quantity at this point
IIRC the manual says that you need to remove the whole timing cover to replace that sensor.
I found someone that detailed the procedure on his blog to do it without too much work: Carfix: 2004 Suzuki Forenza check engine light code P0342
I was able to do mine via the engine support hole in the cover. You need a special socket to do this...
Mario is offline   Reply With Quote Quick reply to this message
Old 02-24-2011, 06:17 PM   #9 (permalink)
podz is on a distinguished road
awesome link took 30 minutes n i just used a 6 or 7 mm socket for that bolt saved me lotsa $. some places wanted 109 to 200$ for the sensor but i got it from the chev dealer for 70
podz is offline   Reply With Quote Quick reply to this message
