torque specs please. - Suzuki Forums: Suzuki Forum Site
Old 03-23-2010, 01:46 PM   #1 (permalink)
leovcp is on a distinguished road
Question torque specs please.
hi everyone , i need to know what is the torque specs for the cylinder head bolts. thanks
leovcp is offline   Reply With Quote Quick reply to this message
Old 03-23-2010, 09:08 PM   #2 (permalink)
Banned
android2 is on a distinguished road
Default leovcp!!!!.....
To maintain a tight leak-free seal, the bolts must the tightened in the proper sequence and torqued to specifications
In an engine with four inch cylinder bores and peak combustion pressures of around 1,100 pounds per square inch, each cylinder exerts about 13,827 lbs. of pressure against the cylinder head at full throttle. In fact, head bolts may have to handle loads of more than five tons per bolt at wide-open throttle!
The clamp load that is typically required to keep the head gasket sealed under these operating conditions is about three times the peak pressure exerted against the head (this is called the "lift-off" force). As a result, the bolts around the combustion chamber have to exert a combined force of about 41,500 lbs. to hold the head in place. If each cylinder has four head bolts around it, each bolt has to exert a clamping load of 10,375 lbs. If there are five head bolts per cylinder, the load needs to be 8,300 lbs. per bolt. If there are six bolts per hole, then the load required drops to 6,916 lbs. per bolt.
android2 is offline   Reply With Quote Quick reply to this message
Old 03-24-2010, 08:04 AM   #3 (permalink)
exist3nce's Avatar
Gallery: 9
Interesting reply there android2.
However if you are looking for the torque specs, are you talking about stock OEM bolts or aftermarket ones like ARP? The stock ones are stretch bolts I believe which means 1 time use only!
I installed the ARP bolts tightened to 80 ft lbs, in 4 steps and in the proper order.
2004 Optra/Forenza/Lacetti - 225whp - Haltech Sprint500 - CT12B - Professional P&P - Getrag F28 6spd - KW V3 Coilovers - FX35 Retrofit
2002 IS300 5MT - 615whp - AEM EMS - GT4088R - Built 9.5CR - R154 - TRD LSD - SupraTT T/B - Varex - LS430 Retrofit
exist3nce is offline   Reply With Quote Quick reply to this message
Old 03-24-2010, 10:27 AM   #4 (permalink)
dang i would of never thought sooo much pressure is occuring in the combustion trying to kick the head of the motor, and thanks for the reply guys, i found out that the torque spec for the cylinder head bolts is 18 ft. lbs. (25 Nm) and turn the bolts another 3 turns of 90 degrees using the angular torque gauge KM-470-B , wich i dont have so i printed out a degree wheel and used it to get the perfect 90 degree turns!
Old 05-29-2016, 09:27 AM   #5 (permalink)
pacman20 is on a distinguished road
Default 2008 suzuki xl-7 6 cylinder
I am having the timing chain replaced. I would like to know what torque or torques are required to get the job done. Thank You.
pacman20 is offline   Reply With Quote Quick reply to this message
