crankshaft sensor - Suzuki Forums: Suzuki Forum Site
Old 01-07-2008, 10:45 PM   #1 (permalink)
cwjo68 is on a distinguished road
Question crankshaft sensor
So I have a 04, auto, Forenza, which was throwing a check engine light.. After reading the code I found it to be the crankshaft sensor, so I cleaned the connector where it ties into the wiring harness on top of the engine. So the check engine light goes away..
So have any of you replaced this sensor? and if so how big of chore is it? I managed to follow the wire to the accessory area but lost it there. I was just wondering what needs to be pulled off and where it connects at?
cwjo68 is offline   Reply With Quote
Old 01-08-2008, 11:10 AM   #2 (permalink)
Mario is an unknown quantity at this point
P/S Pump and A/C compressor have to be moved out of the way...
But you might also need the dealer ScanTool to complete the CrankShaft learning procedure.
You're lucky yours DID trow a Service light... mine was intermittent while hot and made the engine hard to restart. Took me 5 visits to the dealer to fix this.
Mario is offline   Reply With Quote
Old 01-08-2008, 12:07 PM   #3 (permalink)
Anyone know if I need the dealer ScanTool, like Mario was saying?
or you don;t think this would be covered under warranty?
Old 01-08-2008, 02:45 PM   #4 (permalink)
Zipper's Avatar
Gallery: 28
Warrenty, and I would asume its Powertrain, so thats the longer part of the warrenty
Old 01-08-2008, 05:00 PM   #5 (permalink)
ditto. when in doubt, take it to the dealer
tallkid is offline   Reply With Quote
Old 01-11-2008, 06:53 PM   #6 (permalink)
Doohickie's Avatar
Doohickie
I'm not sure how Suzuki interprets it, but I know for a fact that Hyundai's powertrain warranty does *not* include the sensors. It only includes the mechanicals.
Doohickie is offline   Reply With Quote
Old 01-12-2008, 01:36 AM   #7 (permalink)
kinkyllama's Avatar
If it's the sensor then why do you need to follow the wire in the other direction?
Anyways I just got a code today for mine and need to replace it but my cars getting some body work and paint done for the next week and a half so I won't know anymore untill then.
btw a new sensor was around $68 from the dealer.
Are you sure? that really freakin sucks for a stupid sensor.
How did it act when it didn't want to restart? I took my car into my mechanic to see why the cooling fans weren't turning on, and what was draining the battery. I come back to pick up the car and I start it up (starts up perfect) bring it to the back of the shop to see if it threw any new CELs. Afterwards it wouldn't start, just cranked strong. Scanned the CEL again and crankshaft sensor is bad. After about 7 different attempts to start the car it finally does out of nowhere.
Ebay store:
Myspace:
Old 01-12-2008, 07:35 PM   #8 (permalink)
The learning part might not be mandatory, but they did it to be sure of the signal quality from the sensor I guess. With no codes, they weren't 100% that was the right part to replace.
Most of the time, like this: http://pages.infinit.net/drf666/Problem.mp3
the rest of the time, it just was long to catch, like a car with worn spark plugs.
Old 01-13-2008, 09:59 PM   #9 (permalink)
SuzukiTech
Removal
1)Disconnect the negative battery cable.
2)Remove the power steering pump, if equipped.
3)Remove the A/C compressor.
4)Remove the rear A/C compressor mounting bracket bolts and the rear A/C compressor mounting bracket.
5)Remove the accessory mounting bracket by removing the bolts.
6)Disconnect the crankshaft position (CKP) sensor connector.
7)Remove the CKP sensor retaining bolt.
8)Gently rotate and remove the CKP sensor from the engine block.
Installation
1)Insert the CKP sensor into the engine block.
2)Install the CKP sensor retaining bolt. Tighten:
Tighten the crankshaft position sensor retaining bolt to 8 N·m (71 lb-in).
3)Connect the CKP sensor connector.
4)Install the accessory mounting bracket with the bolts. Tighten:
Tighten the accessory mounting bracket bolts to 37 N·m (27 lb-ft).
5)Install the rear A/C mounting bracket. Tighten:
Tighten the rear A/C mounting bracket bolts to 35 N·m (26 lb-ft).
6)Install the A/C compressor.
7)Install the power steering pump.
8)Connect the negative battery cable.
Suzuki Tech2 is needed for the "Tooth Error Correction CKP"
When an ECM is reflashed, initialized or replaced, and drive plate of fly wheel has been replaced, follow these procedures to relearn the crankshaft position (CKP) system variation:
WARNING: To avoid personal injury when performing the TEC learn procedure, always set the vehicle parking brake and block the drive wheels. Release the throttle immediately when the engine starts to decelerate. Once the learning procedure is completed, engine control will be learned to the operator, and the engine will respond to throttle position.
1)Stay the gear parking or neutral.
2)Install the scan tool and select “TEC (Tooth Error Correction) LEARN” menu.
3)Start the engine with A/C off.
4)Keep the engine coolant temperature above 65°C (149° F)
5)Put the acceleration pedal above 4000 RPM until the fuel cut-off occurs.
6)Wait 10-15 seconds.
7)Fulfill this procedure again if the scan tool does not display “OK” message.
8)Turn the ignition switch OFF.
9)Turn the ignition switch ON and then clear the DTC code.
SuzukiTech is offline   Reply With Quote
Old 01-13-2008, 10:32 PM   #10 (permalink)
kinkyllama's Avatar
Originally Posted by SuzukiTech View Post
=5)Put the acceleration pedal above 4000 RPM until the fuel cut-off occurs.
Thanks! I couldn't find this in my service manual
Can you tell me how long it takes to replace the CPS acording to the manual?
Also what do you mean by "fuel cut-off" as I qouted above, the rev limiter? If not please explain.
Ebay store:
Myspace:
