Old 12-14-2007, 01:17 PM   #11 (permalink)
Originally Posted by rustik23 View Post
i dont think so car is only 10 months.
There has been known quality issues with our car. So its possible that you may have gotten a bad spark plug.
Old 12-15-2007, 12:23 AM   #12 (permalink)
Intruder's Avatar
Intruder
Get an OBD-II code scanner and plug it into your diagnostics box under the hood.
More often than not, idle issues in new cars are due to faulty sensors in places everyone mentioned. My first guess was CKP.
Don't go driving around all over creation until you know whats wrong. Your timing could be off and could cause major problems if not fixed.
Do routine checks under the hood to make sure all electrical sensors and connectors you can see are plugged in tightly. When my Reno was new I found the wires on the disty were not pushed on all the way and it seemed to smooth the idle a little.
Intruder is offline   Reply With Quote
Old 12-17-2007, 04:58 PM   #13 (permalink)
rustik23 is on a distinguished road
i just went to dealership they said it has happened because i didnt use clean gas, even though i always used the super so now i have to pay 125 +tax dollars so they flush the whole system. And they said since it has nothing to do with suzuki i have to pay for it.
rustik23 is offline   Reply With Quote
Old 12-17-2007, 05:16 PM   #14 (permalink)
Clean gas? Who do you buy gas from? El Cheap Gaso Station? Also what grade of gas are you buying? Super is a marketing term by the way.
Old 12-17-2007, 05:18 PM   #15 (permalink)
Most of the time i buy from Mobile 93 grade. 3.50 a gallon
Old 12-17-2007, 05:25 PM   #16 (permalink)
Do not put 93 grad gas in your car. You don't need it and as you have seen it does your car harm than any good. Get the cheap 87 grade and you be much better off.
Old 12-17-2007, 05:34 PM   #17 (permalink)
i think it is because i used to drive with low gas all the time with my gas light on.
This must be the problem.
Old 12-17-2007, 09:06 PM   #18 (permalink)
Dj Low Proz's Avatar
Gallery: 9
Dj Low Proz is on a distinguished road
whats wrong with 93 gas. I just started using 89 gas @ 3.09
Dj Low Proz is offline   Reply With Quote
Old 12-17-2007, 11:08 PM   #19 (permalink)
Zipper's Avatar
Gallery: 28
Ok... lets put it this way
Your car is designed for 87. It rund perfectly fine on 87. Its power is designed for 87. Its ECU curve is designed around 87.
Now you put in a gas that doesn't detonate as easily. You might be hurting performance because it dosn't have the compresstion to take advantage of the harder to ignite fuel.
Point 2, your using the second worse gasoline. Why not just use Barely Petroleum (BP/Amaco=arco).
If your going to use the cheep places, remember to Techron your system on occasion. I know a Chemical engineer at Chevron. He'll Techron on a long trip, then redo it on the short trip around town where he went, then once more on the trip home. Keeps the engine, and everything else clean.
Weird thing is, premium in california is 91. Don't need the extra octane or two really for premium
Old 12-17-2007, 11:23 PM   #20 (permalink)
Gallery: 9
so thats a no go on buying higher octane gas for my 07 reno?
