Clutch bleeding - Suzuki Forums: Suzuki Forum Site
Old 12-08-2007, 07:59 PM   #1 (permalink)
TTGOTH's Avatar
TTGOTH is on a distinguished road
Default Clutch bleeding
This might have been done in an older thread. I started to have problems shifting, And the clutch pedal went down with NO resistance. After looking at it for some time I decided to bleed the clutch before buying a new clutch. It now works fine.
TTGOTH is offline   Reply With Quote Quick reply to this message
Old 12-08-2007, 11:49 PM   #2 (permalink)
Zipper's Avatar
Gallery: 28
How did you do this. Alot of us are fairly noobs
Zipper is offline   Reply With Quote Quick reply to this message
Old 12-09-2007, 10:23 AM   #3 (permalink)
theres probably a bleeder valve. you'd bleed it the same way that you bleed your brakes....that's my assumption anyways.
tallkid is offline   Reply With Quote Quick reply to this message
Old 12-10-2007, 07:46 PM   #4 (permalink)
exist3nce's Avatar
Gallery: 9
Yes to bleed the clutch there is a small nut with a spout on it (the bleeder valve) that you loosen right at the quick-connect on the transmission bellhousing. This is best done with 2 people, one watching and controlling the bleeder valve, and the other to push and raise the clutch. While the valve is open, push the clutch in (it will probably fall right to the floor and not come back up). You should see some fluid and maybe air bubbles comming out the bleeder. Now close the valve, and raise the clutch back up to its normal position (this may have to be done by hand). Open the valve and repeat until there are no more air bubbles comming out the bleeder valve. Pump the clutch several more times and it should return to its normal stiffness and feeling. You might need to top up the brake fluid after this procedure depending on how much was lost (the hydraulic clutch shares its fluid with the brakes).
2004 Optra/Forenza/Lacetti - 225whp - Haltech Sprint500 - CT12B - Professional P&P - Getrag F28 6spd - KW V3 Coilovers - FX35 Retrofit
2002 IS300 5MT - 615whp - AEM EMS - GT4088R - Built 9.5CR - R154 - TRD LSD - SupraTT T/B - Varex - LS430 Retrofit
exist3nce is offline   Reply With Quote Quick reply to this message
Old 12-20-2007, 09:40 PM   #5 (permalink)
TTGOTH's Avatar
What he said.....
Old 06-17-2012, 06:39 PM   #6 (permalink)
econguy is on a distinguished road
I need to bleed the air out. Does anyone have a photo or diagram that shows where the bleeder valve is?
econguy is offline   Reply With Quote Quick reply to this message
Old 06-18-2012, 03:41 AM   #7 (permalink)
aixelsid is on a distinguished road
it looks just like one on a break caliper. I think it is on the side of the tranny where the motor and bell housing come together
aixelsid is offline   Reply With Quote Quick reply to this message
Old 07-22-2014, 11:43 PM   #8 (permalink)
funkz24 is on a distinguished road
I think this just happened to me, I changed the rear brake pads less than a week ago. For the past two days the transmission had been acting funny, it was sometimes difficult to shift into gear. Today on the way to work I was having trouble shifting, I had to pull off with my hazard lights on because I couldn't get out of neutral. I parked at work and couldn't get in to any gear when I wanted to leave. I laid on the floor and was looking to see if something had broke, I was able to push the clutch pedal in using 1 finger, absolutely no resistance. I had to bum a ride home and my car still sits in the parking lot. Any comments or ideas would be great...
funkz24 is offline   Reply With Quote Quick reply to this message
Old 07-21-2015, 06:41 PM   #9 (permalink)
olsen.pete@gmail.com is on a distinguished road
Talking
Below the Battery Tray, look for the rubber hose that goes from the frame to the transmission bell housing. That is your clutch hose. Use a 10 MM wrench to loosen the bleeder screw, (CAUTION, USE TWO HANDS, THIS IS PLASTIC AND CAN BREAK EASILY).
Normally, you would want to bleed the air out using two people, but you can loosen the bleeder, push the clutch pedal to the floor and leave it there.
Tighten the bleeder and then pull the clutch pedal up with your hand.
You might need to do this a couple of times to get all the air out.
Refill brake reservoir with DOT3 brake fluid.
If your quick connect is broken or leaking that bad, then you might need to replace the rubber ring that is under the quick connect. It is a SQUARE RING, NOT AN O RING. (although I have had some luck with an O Ring)
If you need to replace the quick connect because it is broken,
Auto 7 part number 212-0016 will work.
olsen.pete@gmail.com is offline   Reply With Quote Quick reply to this message
Old 12-09-2015, 09:23 PM   #10 (permalink)
systemzero is on a distinguished road
Default Sad first post:( disappearing clutch
I just bought the car as is and when I was driving it home the clutch just disappeared. I bled the clutch later at home and the clutch came back. I take it out again thinking I'm good, and in about the same distance it did it again.
What was the out come for you other guys that had the same problem? Was it just the line that need to be replaced? Are these occurances isolated to the line? Or is it sometimes the Clutch Master on the pedal, or something stupid like a air leak from somewhere near the reservoir?
This is my first Suzuki but I'm very competent working on cars, my summer daily is a mk1 Scirocco 1.8 8vT
I'm off to Sudbury till Monday or so and would love to figure out whats up with this car so I can fix it and start to enjoy it when I get back. Hope you guys say its just the line
systemzero is offline   Reply With Quote Quick reply to this message
