Old 05-28-2006, 04:07 PM   #31 (permalink)
Zipper's Avatar
Gallery: 28
Originally posted by rosadmr@May 28 2006, 08:36 AM
Hey everybody!
I was reading some of the posts and I feel bad about the flashing lights that people were getting. I asked my dealership because they to had no idea how to disable the DRL's and when I told them about the lights they said that it maybe more than the disabling of the DRL's??? I know that when the plug was put back in the lights shut off? The dealer said that the flashing hold button is for the transmision, nothing really to do with the lights but that is what they said. I did the modification on a 2005 Forenza EX wagon and now for 2 weeks nothing, no flashing lights and I can choose to use just my fog lights or my HID's. So I hope that your problem goes away and you can enjoy not having the DRL's. I hope that I helped most people and for those it didn't work for sorry.
Dennis
Same here.
I think they might of removed the wrong wire
Old 05-28-2006, 10:41 PM   #32 (permalink)
g2064's Avatar
g2064 is an unknown quantity at this point
as you can clearly see in the video that i put up i did not remove the wrong plug
i removed it and it and if u c in the other video my lights where
flashing
What will become of the Reno
g2064 is offline   Reply With Quote
Old 05-28-2006, 11:34 PM   #33 (permalink)
kas
kas's Avatar
kas is an unknown quantity at this point
flashing
Maybe it's different with the Reno's ... Dude said a 05 Forenza... That's what I got and I did it and my car runs fine...
kas is offline   Reply With Quote
Old 05-29-2006, 12:59 AM   #34 (permalink)
dr3wrocks
might have something to do with it being an automatic?
dr3wrocks is offline   Reply With Quote
Old 05-29-2006, 02:15 AM   #35 (permalink)
g2064's Avatar
Post
no i dought it because after i shut off the car plugged it back in reset the code on there unplugged it and turned on the car it was all fine read the code but nothing came out so i have no idea what was wrong all i know there is no diffrence in driving conditions evreything seems the same as before no drl's of course but thats about it so if it does happen to anyone in a "RENO"
just do as i did and u should be fine......
Old 05-29-2006, 08:26 PM   #36 (permalink)
masterbiscuit's Avatar
masterbiscuit is an unknown quantity at this point
Yeah dude, I have a Reno and it's an Auto. No issues from the first time out. A question though, the first time you removed it, was the car running at the time? How about the headlight switch, was that on?
If neither one, then just chalk it up as a fluke and be glad all is running well. The good news it that if anyone else has the same problem as you, there's a possible solution!
The END of Florida!
masterbiscuit is offline   Reply With Quote
Old 05-29-2006, 09:03 PM   #37 (permalink)
ChiPPy
Has anyone figured out if you can change what lights are used as the DRLs? I would prefer my fogs were the DRLs.
I think I'll have to look at the schematics myself, because I also don't like the way the low beams turn off when you turn on the high beams. I find it leaves a huge "hole" in your field of vision.
ChiPPy is offline   Reply With Quote
Old 05-29-2006, 10:06 PM   #38 (permalink)
g2064's Avatar
Post
no car was not running
no the lights where not on.........
as far as a possible soloution i found the solution for my car but it my diffrent
for others
Old 06-03-2006, 12:49 PM   #39 (permalink)
Intruder's Avatar
Intruder
So which color wire(s) would you wire a switch to if you wanted to toggle the DRL's on and off?
Intruder is offline   Reply With Quote
Old 06-03-2006, 04:45 PM   #40 (permalink)
Zipper's Avatar
Gallery: 28
its hard to tell in mine, there all wrapped. Its the plug closest to you... the ine with less wires, not more.I almost did that one
