Old 03-01-2008, 07:04 AM   #1 (permalink)
ReVeNgE is on a distinguished road
Default Mounting Sub in rear panel thingy...
hey, i was thinking of getting a 8" or 10" JBL sub... and i wanted to ask, if i mount it on the rear panel... you know, the one behind the rear seats that comes off... would i get good bases ? or its better to get a box for it ? .... i dont want to make the whole car shake... i just want to add some bass... so would the trunk act somewhat like a box ? or would that make the sub useless ? ... THANK YOU !!
ReVeNgE is offline   Reply With Quote
Old 03-25-2008, 09:36 AM   #2 (permalink)
federic0's Avatar
Gallery: 4
federic0 is on a distinguished road
Subwoofers need an enclosure to work properly. Whatever sub you buy will have its own 'ideal' enclosure specs (i.e., it'll tell you the proper volume for an enclosed box and a ported box), and it's a good idea to buy/design your enclosure to meet those specs as closely as possible. A single 8" or 10" sub, in a good enclosure, will add a lot to your stock system without blowing the doors off. If space is an issue, Pioneer makes 10" and 12" inch shallow subs that take up a lot less room and require a lot less enclosure volume. Here's my install: [ federic0's 2006 Suzuki Reno on CarDomain - Page 2 ]
federic0 is offline   Reply With Quote
Old 03-25-2008, 03:52 PM   #3 (permalink)
lamborgini112 is on a distinguished road
Also your sub is gonna sound different if you have a ported setup or a sealed set up. Federic0 your setup looks great by the way i am working on something similar except with ports in the top above the wheel wells and on both sides. Mad props on your amp rack. alot cleaner looking than mine.
lamborgini112 is online now   Reply With Quote
Old 03-25-2008, 05:43 PM   #4 (permalink)
federic0's Avatar
Gallery: 4
Thanks, lamborgini. That was my first install, and I wasn't brave enough to try porting it; though I hear it sounds better if you do it right. Post up some pics of yours when you get it in.
Old 04-01-2008, 07:00 PM   #5 (permalink)
Rafael
Revenge:
Yes you can use that panel to mount a sub-woofer.
Free air subs (or IB for infinite baffle) are made to be used when a box is not an option. So, just make sure the sub you put there is light, and low powered so that it wont sag over time, unless you make some reinforcements.
Here are some free air options:
free air sub woofer, Car Electronics, Parts Accessories items on eBay.com=
I would go with the JL.
And yes it will satisfy what you are looking for.
my .02
Rafael is offline   Reply With Quote
Old 04-02-2008, 03:53 PM   #6 (permalink)
thanks for the info.. to be honest i've never heared of free air woofers before... its good to know.....
Old 04-07-2008, 07:13 AM   #7 (permalink)
Ironrat's Avatar
Ironrat is on a distinguished road
or you can use a powered sub like a Infinity Basslink(best option) or a Kenwood KSC-SW1 or a Kenwood KSC-SW10.
Ironrat is offline   Reply With Quote
Old 05-18-2008, 09:39 PM   #8 (permalink)
MrPerfect-10 is on a distinguished road
Oi matey, with the build that you did, can you still retrieve the spare and the other road side safety stuff?
I am starting on my subs next weekend, and I am liking what you done
MrPerfect-10 is offline   Reply With Quote
Old 05-19-2008, 11:59 AM   #9 (permalink)
federic0's Avatar
Gallery: 4
Yea you can still get to everything; I even had extra space for jumper cables. Idk if it shows up in the pics at all, but the amp platform is hinged on the frontside and is connected with 2 "L" brackets at the backside. If I need to get to my spare/tools, all I have to do is take out 4 screws and the whole thing rotates up. Good luck with your install!
Old 05-19-2008, 08:56 PM   #10 (permalink)
Cheers mate, this was a genius idea I will try and do your design justice, although I am using Alpine Type-R Series subs so I am going to have to build up a box around it so the magnent will have some breathing room
