Old 05-17-2007, 11:50 AM   #1 (permalink)
dumbo is on a distinguished road
Default radio tuning
my radio tunes in ok, and is ok if switched off by off button. problem is it looses its memory when the ignition is turned off. help please
dumbo is offline   Reply With Quote
Old 05-18-2007, 04:49 AM   #2 (permalink)
beancounter69's Avatar
beancounter69 is an unknown quantity at this point
Sounds like a simple wiring fault. The connector at the back has a trickle feed from the battery to retain memory - is it connected? Can be a bigger problem on most radios as this fault can also disable them so that you would have to enter the security code each time - assuming you have the code?
Beancounter
beancounter69 is offline   Reply With Quote
Old 05-20-2007, 04:29 AM   #3 (permalink)
Hi Beancounter.you were spot on. loose connection behind the radio. much obliged. thank you very much .Dumbo
Old 05-20-2007, 02:06 PM   #4 (permalink)
Pleased to be of help
Beancounter
