Old 05-13-2005, 02:01 AM   #1 (permalink)
ChillinSX04
Just got a full kicker system replace stock 6 1/2 to kicker SL60, a 10inch L5 sub, an KX400 mono amp with Tsunmi 2 frad w/sub ground kit. Ran Dynmat threw out the car system thumps.
ChillinSX04 is offline   Reply With Quote
Old 06-22-2005, 10:45 AM   #2 (permalink)
Blackbox
how hard was it to replace the head unit.....i am trying to figure out best way to get to the radio with out removing intire dash?
Blackbox is offline   Reply With Quote
Old 07-02-2005, 11:36 PM   #3 (permalink)
ChillinSX04
Question
there's no other way, it's easy, it's about 20 or some screws it about a half an hour
Old 07-05-2005, 02:54 AM   #4 (permalink)
ShortBuSX
Dude, dont listen to him...he obviously had someone do his head unit install, cause its rather easy and it doesnt require removing the entire dash. Its about 7 screws. For starters pull out the ashtray. There are 2 screws at the top and one in the back of it(the ashtray)...once you do that just tug on the ashtray opening and the lighter thing. Tug on that and it should remove the plastic trim. Now all you have are the 4 screws holding in the headunit and they are visably displayed...so you cant miss them.
After that go buy a harness that will fit our factory harness and make the proper connections. I usually solder mine and finish the with heat shrink tubing, makes for a very clean install with excellent connections.
If you need a diagram of the wiring, let me know and I'll post it for you.
And the only reason to remove the dash would be to Dynamat it...but even then I wouldnt! I fear rattles too much for all of that.
<img src="http://www.suzuki-forums.com/images/....gif">
ShortBuSX is offline   Reply With Quote
Old 07-05-2005, 10:02 PM   #5 (permalink)
silversuki's Avatar
silversuki
I thought you would only have to take off the trim piece around the head unit,2 air vents and the hazard button!?
silversuki is offline   Reply With Quote
Old 07-06-2005, 02:42 PM   #6 (permalink)
ShortBuSX
Yeah, exactly...but you gotta go through the ashtray to do that.
Old 07-06-2005, 09:36 PM   #7 (permalink)
silversuki's Avatar
silversuki
Not on my '04 Aerio SX!! I'm pretty sure my trim piece just pops off and then right there is the radio. 4 screws and your done!! Ashtray not needed.
Old 08-19-2005, 11:23 PM   #8 (permalink)
ChillinSX04
I took off the whole dash to install other things like int. LED lights at the feet also a wired remote place on the side of the wheel to control the stock radio. I help install my alarm too. I didnt want the wires to be accessable to would be thieft and to check out the wiring of the Aerio
Old 08-19-2005, 11:24 PM   #9 (permalink)
ChillinSX04
I'm looking to get a better Batt. for the Aerio and brands anyone know about with high recommendations??
Old 01-20-2006, 02:28 AM   #10 (permalink)
djfourmoney
Optima....
If you wait another day, I can get your fittment at work.
A. Thomas -
1995 Dodge Neon Highline (I/Cam/H/E= 14 seconds on DR's)
2003 Dodge Neon SRT-4 (Stage 1 + DR's = 13 seconds)
djfourmoney is offline   Reply With Quote
