Stalls When Heater Is Turned On
When starting my 04' Forenza it starts rough then revs up high then idles really low almost stalling, then if I put on the Heater it will immediately stall. I thought I had solved the problem when I changed a hose that was complete mush and had holes in it that went from the throttle body to the manifold cover. Problem still exisits.
Even when I do not put the heater on it sounds like the a/c compressor is clicking to come on and will stall when compressor comes on. Also, the radiator fans are coming on as soon as I start the car even when cold. Please help. Thanks!
