Old 08-19-2008, 03:52 AM   #1 (permalink)
Enza is on a distinguished road
Default auto tranny plug
so i was messing with the coolant system and the radiator in my '05 suzuki forenza and i pulled one of the plugs for the transmission fluid and now i'm about 3 and a half quarts low on tranny fluid and i can't find the plug so i can top it off. anyone now where it is?
Enza is offline   Reply With Quote
Old 08-19-2008, 02:28 PM   #2 (permalink)
Shenanigans's Avatar
Shenanigans
yup, there are two plugs on the transmission one for fill and one for drain.
Both have a 8 MM (metric) square drive tool needed to remove them.
The fill one is just above the motor mount/transmission mount on the back near where the long driveshaft somes out of the transmission, you gotta put the car on jack stands or need access to a lift, the car needs to be level while you fill the tranny.
I've tried three times to make a tool for removing this plug so that I could change my tranny oil but without any luck. If anyone else could provide suggestions on this, that would be great.
there is a service manual for the Chevrolet lacetti floating around that describes how to fill and drain the transmission and a part # for the specialty tool you'll need (8mm square drive).
Hope this helps.
2004 Chev Optra 5
Shenanigans is offline   Reply With Quote
Old 08-20-2008, 03:34 AM   #3 (permalink)
k thx my brother-in-law took a look at it and was able to put the tranny fluid in while i was at work. he's a mechanic and said he has done it on other models so i guess he just brought over something from his shop to help. thats where i thought the plug was but i couldn't reach it.
thank you for the measurements
