Old 04-03-2008, 12:42 AM   #1 (permalink)
Skulz's Avatar
Skulz is on a distinguished road
Default Plugs, wires, and trans fluid
Ok I'm getting close to 50000Km and GM is telling that they will use original factory wire and plugs. I was wondering what wires can i use I was thinking of Nology wires but I'm not sure of the plugs. My other question is how the hell do you change the trans fluid on this thing. There is no cap nothing. I serously doubt that the trans fluid will last me a life time. Any help and suggestions would greatly be appreciated.
Thanks,
Skulz.
Skulz is offline   Reply With Quote
Old 04-03-2008, 08:13 AM   #2 (permalink)
Easy E is on a distinguished road
Well the trans fluid is a lifetime fluid, but if you still want to change the fluid then you will have to just remove the pressure plate to drain the liquid...
Easy E is offline   Reply With Quote
Old 04-07-2008, 02:07 PM   #3 (permalink)
SuzukiTech
changing the tranny fluid is simple if you have lift access. there is a drain plug on the bottom of the tranny, then there is a plug on the back side of it right next to the rear tranny mount. thats the fill plug, just like filling a diff on a truck add the fluid until it comes up to the hole
SuzukiTech is offline   Reply With Quote
Old 04-07-2008, 02:27 PM   #4 (permalink)
kinkyllama's Avatar
Nologys are probably the best wires out there, but by very little. There cost doesn't justify the price...they are nearly double anything else. Hell I got an MSD coil and wires for allot less than just nology wires.
Ebay store:
Myspace:
Old 04-08-2008, 07:50 PM   #5 (permalink)
Skulz's Avatar
Ok I was not sure of MSD as Nology were the only wires that worked best on my other ride. I'll check out MSD's website for our cars. Thanks.
Old 04-08-2008, 08:27 PM   #6 (permalink)
kinkyllama's Avatar
They don't make wires for our cars. I just modded some SRT-4 wires, I needed the coil to work with my MSD DIS-2
Ebay store:
Myspace:
Old 04-10-2008, 11:52 PM   #7 (permalink)
Skulz's Avatar
Would a used MSD dic2 off of a PT GT work in this situation as well.
Old 04-11-2008, 04:41 AM   #8 (permalink)
kinkyllama's Avatar
The MSD DIS-2 is universal...it's the coil and wires that aren't so universal. You'll need to build a special driver for it to work on your car though. See the how-to section on daewootech for that one.
Ebay store:
Myspace:
Old 04-11-2008, 12:45 PM   #9 (permalink)
Skulz's Avatar
Oh ok thanks.
Old 08-12-2008, 01:12 PM   #10 (permalink)
Skulz's Avatar
Dos anyone know the mm size of our factory wires?
2006 Chevy Optra5 auto, 1160wats in the doors JVC Deck, K&N drop in Painted side mirrors and painted mirror cover plates and adjusters inside the car. Painted DTech Cover and fuse cover. Hopefully a bit more next year, looking at 2 12" hopefully Infinities in a custom enclosure, BMS intake, rims, factory wing looking painted just needs to be installed, and painted brake calipers.
