Old 03-26-2008, 02:57 PM   #21 (permalink)
ikon is on a distinguished road
Originally Posted by kinkyllama View Post
Hmm. . .
Hopefully a few other members chime in. I've had a performance intake much longer than factory one so it's hard for me to remember. Are you sure it's low RPMs and not just lower RPMs at lower speeds (i.e not above say 2nd gear)? That'd make sense to me since it's a SRI it'd suck in all the hot air being next to the engine untill you get some air flowing.
Setup for just an intake or overall?
Best intake=BMS CAI which you can order from me. They're on back order for less than a week right now.
You can use it as either a CAI or SRI...so say you're worried about sucking up water you can take off the extra length, and swap the filter to the first peice for a SRI for that time of year.
Yup saw the BMS, but not sure if it will fit my set-up as this model comes with the VGIS just after the throttle body. The intake pipe connects side way whereas the BMS uses a plenum and connects from the top.
Here's a picture of the stock intake:-
ikon is offline   Reply With Quote
Old 03-27-2008, 12:35 AM   #22 (permalink)
Aztec Ninja's Avatar
Aztec Ninja is on a distinguished road
Originally Posted by ikon View Post
Hi ya guys, I'm a noob and this is my post here. Just curious, such air intake modifications ~ where are the gain expected? Any adverse effect if it's done on an auto tranny ride?
Well from what I heard most of the gains are supposed to be in the higher range but with this set up I felt it from the get go, but then again the stock system was so constricted I'm not suprised.
S stands for super man... or super car... or something
Aztec Ninja is offline   Reply With Quote
Old 03-27-2008, 12:52 AM   #23 (permalink)
Any worries with the bigger open filter that the throttle body might get foul with dirt and etc?
Old 03-27-2008, 01:01 AM   #24 (permalink)
it's pretty much the same thing only more surface area so more air through the larger tube wich also increases the mass of air, not to mention that less friction means less heat so more O2 baby.
Old 03-27-2008, 04:31 AM   #25 (permalink)
kinkyllama's Avatar
Do you have the 1.3-1.6?
I still might be able to help you, but nothing as good as the BMS intake
Ebay store:
Myspace:
Old 03-27-2008, 05:21 AM   #26 (permalink)
Optra here is the 1.6 cc using the E-TEC engine with DOHC. For Aveo it's using the 1.4cc DOHC variant. Both engine is from the Korean plant.
Old 03-27-2008, 05:59 PM   #27 (permalink)
kinkyllama's Avatar
I can still help you then.
Can you get a picture of your engine bay for me?
I just bought a 1.6 lanos that has a custom intake that I won't need since I'm swapping a 2.0 into it. It has the same setup, and maybe the same engine as your optra. Do you know your engine code? Depending on how nice the intake is, I'd like around $45 for it.
There is an weapon r intake system available, but it'll cost about $250usd to ship to you. I think it's only a short ram too...you'd be better off doing just about anything else tbh. haha
Ebay store:
Myspace:
Old 03-30-2008, 05:51 PM   #28 (permalink)
azzo540's Avatar
Gallery: 15
azzo540 is on a distinguished road
bms maybe nice but i am keepin my spectre it works great and no need to spend more money for another intake sorry kinky. i will bye othere stuff from you though
azzo540 is offline   Reply With Quote
