Originally Posted by ikon
Ohh thanks for the fast reply. It's just that I'm from the tropics and the weather here is hot and humid, I got a buddy that did his short air ram system and he lost badly in the lower RPM range but it was sweet in the mid and higher range. Could it be his set-up?
Anyway what's the best set-up for Optra?
Hmm. . .
Hopefully a few other members chime in. I've had a performance intake much longer than factory one so it's hard for me to remember. Are you sure it's low RPMs and not just lower RPMs at lower speeds (i.e not above say 2nd gear)? That'd make sense to me since it's a SRI it'd suck in all the hot air being next to the engine untill you get some air flowing.
Setup for just an intake or overall?
Best intake=BMS CAI which you can order from me. They're on back order for less than a week right now.
You can use it as either a CAI or SRI...so say you're worried about sucking up water you can take off the extra length, and swap the filter to the first peice for a SRI for that time of year.
