Old 06-25-2008, 04:42 PM   #71 (permalink)
azzo540's Avatar
Gallery: 15
azzo540 is on a distinguished road
Originally Posted by Jet-Lee View Post
Putting larger and/or additional cabling ANYWHERE in a DC system allows easier transfer of the electricity through the system.
Adding or upgrading the alternator charge cable lessens the resistance that the alternator has to push the power through, thereby reducing strain on the alternator and thus on the engine.
I've got 4ga waiting to be ran from the alt to the battery. 1/0ga waiting for a crimper to ground the piss out of the engine and battery.
Anything to help the [electrical] power flow from point to point helps the engine, period.
The alternator doesn't pull any power, it supplies it, pyaaw.
agreed
and put in better words
azzo540 is offline   Reply With Quote
Old 06-25-2008, 08:48 PM   #72 (permalink)
Gallery: 11
i would look more at the amount and quality of the copper in the cable first and the size of the cable second.
Old 06-26-2008, 01:01 AM   #73 (permalink)
Jet-Lee is on a distinguished road
amount = size
unless you're running in sound quality competitions, you're not going to notice a difference between two different brands of "100% oxygen free copper cable". There just isn't enough difference to notice without an RTA, and that measures sound, not vehicle electronics.
The best cable you can get, actually, is welding cable. It's more pliable and capable of withstanding gross amounts of amperage. That's what matters, not voltage.
Jet-Lee is offline   Reply With Quote
Old 07-12-2008, 01:27 PM   #74 (permalink)
Gallery: 8
posaunemeister is on a distinguished road
so where's a good place to ground the transmission in a Reno? i tried to run a wire from the battery negative to the largest bolt on top of the tranny yesterday and i noticed some serious interference. although the tranny had a smoother shift, the acceleration of the engine seemed to be very sluggish. any recommendations on a good grounding spot for the transmission? thanks in advance.
posaunemeister is offline   Reply With Quote
