p0340 CPS circuit malfunction - Suzuki Forums: Suzuki Forum Site
Old 11-24-2011, 02:52 AM   #1 (permalink)
csgregor is on a distinguished road
Default p0340 CPS circuit malfunction
ok folks,
finally got my bluetooth obdII reader that hooks up to my nokia e71.
its brilliant!!!!! i can check 18 diff gauges,
throttle position, fuel consumption,
common rail pressure
torque generated!!!
so i found that the problem im having with starting is the cam shaft position senser circuit has a malfunction.
Ive seen a few youtube vids. the sensor seems easy enough to change.
do you reckon i should try it? a mechanic is gonna charge me at least $150 to change a 40 buck part that is really a 30 minute job.
has anyone had any experience with this????
im pretty sur eive read it somehwer but i cant find it now.
csgregor is offline   Reply With Quote Quick reply to this message
Old 11-24-2011, 07:08 AM   #2 (permalink)
lumpylarry's Avatar
Depends what year and engine you have..
Replace it is thing but timing it after may require some more tools..
2008 suzuki SX4 sport sedan 5spd FWD
2007 suzuki boulevard C50 SE
2001 suzuki swift 1.3 5spd blue
Old 11-24-2011, 08:06 AM   #3 (permalink)
2008 1.9L ddis engine
f9Q
Old 11-24-2011, 06:18 PM   #4 (permalink)
lumpylarry's Avatar
That makes a big difference. We didn't get a diesel in north America..
Old 12-14-2011, 02:43 AM   #5 (permalink)
latest update! ick!
So it seems that its all related.
bearing noise in idler pulley assembly.
poor starting.
crap fuel economy.
replaced old fan belt which was missing a rib.
it seems the rib has somehow gotten into the timing belt assembly, caused a momentary jam in which my timing belt has
jumped 4 TEETH and sheered a cam pulley tooth.
how it was still running and fine i have no idea but hey!
now i have to wait for parts from melbourne, not perth cos suzuki has such a fantastic well stocked service department. thanks suzuki!
Old 12-14-2011, 04:40 AM   #6 (permalink)
dkguffe's Avatar
Originally Posted by csgregor View Post
latest update! ick!
poor starting.
crap fuel economy.
Waaa... That is one terrible story..
You're a very lucky man that your engine is still in one piece... Phew!
Oz. GV 2006 2.7 Prestige
Rocky Road 2" Lift
ProComp MX6 Adjustables
ARB Deluxe Bullbar
9500 Lbs Winch
Optima YellowTop D34
Roof Cage with 4x HID 4"
HID H11 Lowbeam upgrade
OME Front springs +35kg +25mm
Currently 71.000km +7%
Projects: Dual Battery
Old 12-14-2011, 06:01 AM   #7 (permalink)
mate i am praying! the stuff i've been reading: damaged pistons, covers, cavitys, crankshafts, cylinder heads, bent valves.
so far the recommendations on line have been if thats the damage its cheaper to get another engine
Old 12-14-2011, 06:08 AM   #8 (permalink)
what i dont get is how my car was still running. I did 600km's in it the day before. didnt miss a beat after its little start up chug. and the warning light (only level 1 MIL) was only eveyr second start. I'll be interested to see if i notice a huge improvement when its fixed.
engines arent supposed to run or should run like sh*t with even one tooth slipped on the belt but this had 4 and a sheered pulley, out of alignment injector pump. is that a promo for the F9q engine or a concern? who knows!
Old 12-19-2011, 03:53 AM   #9 (permalink)
ok so the verdict:
car is running ok again! starts fine. new cam pulley. new timing belt assembly. a service. and surprisingly it didnt break the bank. but it did chew all the money i had aside for a front bar. sigh.
